Postby JoeF » Thu Apr 16, 2015 3:42 pm
:thumbup: :arrow: Recommending Rick's urgings on making some specific splats safer:
viewtopic.php?f=25&t=1823
Postby JoeF » Wed Apr 22, 2015 7:00 am
Some Safe-Splat matters in Bill Cummings instruction:
viewtopic.php?f=7&t=182&p=11498#p11498
Postby JoeF » Thu Apr 23, 2015 11:43 am
Motivation:
Burke Ewing with newbie rider in tandem in 1978 had a beaking splat
that invites one to think of Safe-Splat solutions:
Tandem 1978 No Wheels, No Skis
Postby JoeF » Sun Apr 26, 2015 8:45 am
Study
Postby JoeF » Tue May 05, 2015 9:28 am
Experimental tracked gear on a B-36 Peacemaker for soft-field use.
What would an UL version look like?
http://en.wikipedia.org/wiki/Landing_gear The "Light Aircraft" section of that wiki does not address the full range of landing-gear options for hang gliders. Authors might cure the matter eventually. HG landing gear: shoes, barefeet, legs, wheels, skids, skis, Safe-splat devices :thumbup: , spoons, beaking-making raw basebars, rollers, harness bottoms, floats, ... And sometimes: bushes, trees, .... and worse: wires, antenna, cars :(
Postby JoeF » Thu May 07, 2015 12:19 pm
Sacrificial material
Bird splats on mechanical bird:
http://i4.mirror.co.uk/incoming/article ... e-nose.jpg
The mechanical bird was deliberately built with some sacrificial material for use in splats in order to remain safe.
HGs may deliberately have sacrificial materials to be involved in splats.
Postby Bob Kuczewski » Fri May 08, 2015 12:38 am
Hi Joe,
I hope you bring your safe splat experiments to Dockweiler on the 23rd!!!
Bob
Postby JoeF » Fri May 08, 2015 6:16 am
Octave Chanute had the pilot NOT tied to the wing.
Say HG flies over the Dockweiler ocean water ..... THEN, if the pilot was "Chanuted" (NOT tied to the wing),
then the pilot could drop away from the wing before contacting the water; such would give a chance
for the pilot to enter the water and waves without the risk of being water-wave-wrapped with sail and frame.
There was an early 1900s cartoon showing a hang glider pilot doing just such; we have somewhere in forum
a copy of that cartoon. Greblo's offers of gear does not do the "Chanuted" method, as it is common to be tied to the wing;
while loop and carabiner and hang lines are under tension, then one does not get away from the wing.
When at altitude with rescue chute deployment, HG parachutes while still tied to the wing frame in order to keep
some frame as an energy absorbing device ... and not putting the wing-frame into downwind flight where it might
do damage to people and property ... and perhaps give some drag to help on the parachuting effort ...
[[But what are the circumstances where full quick release from the wing might be wanted?]] [ ]
Anyone is invited to bring Safe-Splat experiments (drawings, models, or full-size model, or working systems.
Open tech. Windsports' offer for Safe-Splat is fat wheels at Dockweiler.
Postby JoeF » Mon May 11, 2015 8:51 pm
http://www.pilotworkshop.com/tips/crm
mmmmmmmmmmmmmmmmmmmmmmm
Splat:
http://sparkscolor.com/img/main_splat.gif
sssssssssssssssssssssssssssssssssssssssssssssss
Full front roller
Postby JoeF » Tue May 12, 2015 9:33 am
Neat notice from ARP regarding a discussion in Rigid Wing Hang Gliders on pithing, whack shock absorbing, ...
Read the full topic (many posts)
https://groups.yahoo.com/neo/groups/Rig ... pics/15477
https://groups.yahoo.com/neo/groups/Rig ... ages/15494
Several photos show a shock-absorber whack-cushioning assembly. Still, the pilot swinging through in a stopped basebar would need to consider if pithing would occur. Broken necks are to be avoided; pithing is to be avoided. I did not see a mention of limit lines in the discussion, but I have not reviewed the full group yet.
One might have to join the group to see the messages and photos.
http://www.mediafire.com/view/3a5xad0xb ... kTube2.JPG
http://www.mediafire.com/view/58bkinkmo ... ckTube.JPG
Users browsing this forum: No registered users and 37 guests
