Re: Aerotowing Guidelines
Postby Bill Cummings » Wed Dec 07, 2011 11:00 am
Nobody wrote:Terry,
Do you find any discrepancy in this document ?
http://energykitesystems.net/Lift/hgh/T ... elines.pdf
Yes!
A weak link has more than one function. It should be stressed tested to the breaking limit while hooked to the tow bridle it is to be used with.
A person should not be in line with the bridle during this stress test to the weaklinks’ destruction.
Should any tow ring, carabineer, release, or other hardware be snapped back that could hit a pilot, should they be in line with the tow bridle, this weaklink, tow, bridle combination cannot be used safely. (This hazard should be self evident. It has caused injury and blindness.)
Simply increasing the breaking strength of a weak link for heavier pilots, larger gliders, or tandem flights without consideration of the stretching of a tow bridle or the maximum working load of a release is inadequate planning.
A weak link used only for the sole purpose of preventing damage to the vehicle (glider) can be too strong. It could easily break at so high of a speed that the glider would pitch up beyond the pilots ability to prevent the start of a loop or result in a break stall, tuck, tumble and collapse.
The weak links’ maximum breaking strength should not be so high that it is beyond the pilots ability to prevent a stall when it separates.
There are more considerations for weak link strength but they pertain to ground based towing and the response above was made with aero-towing in mind.
All towing should be done with the idea that you have more options available in free flight than when under tow.
Should a tow stop for any reason like motor failure due to a multitude of causes, unintended release, line breaking, weak link break, stupidly pulling the release when the pilot meant to pull a zipper cord or VG cord, you should now be in a situation where you haven’t flown yourself into a corner.
At any second during the tow you should have planed to be off tow and be able to land safely.
Not down wind, into a full parking lot, into bushes, down wind of a hangar, on a clothes line, into the fence, into the pond, behind a plane in the run-up area, on the loose dog, on a nude sunbather, on the FAA inspector, in the ditch, on the dolly, into the electrical sub station, on the spinning prop of the tug, into the glass greenhouse, into the hells angels bikes, on the state trooper’s car, on the church steeple, on the flag pole, --- HUH? ---WHAT? -------------YOU WEREN’T THINKING AHE-
AD? WHAT’S THE MATTER WITH YOU?
Postby TadEareckson » Wed Dec 07, 2011 1:34 pm
Yes!
Hey! He asked Terry! You can't answer that!
Oh, what the hell, I'd rather have someone who can read and write anyway.
Tost Flugzeuggeratebau
Weak links protect your aircraft against overloading.
Steve Kroop - 2005/02/09
A weak link is there to protect the equipment - not the pilot. Anyone who believes otherwise is setting himself up for disaster.
Dynamic Flight
The purpose of a weak link is solely to prevent the tow force from increasing to a point that the glider can be stressed close to or beyond its structural limits.
1. Assuming the weak link is a loop of string installed on a bridle, yeah. So?
2. And just how many people do you know who acually do that?
3. Hell, how many flight parks do you know who actually do that?
Can you cite an incident of anybody who getting so much as bruised when using all low stretch materials for towline and bridle/release system components?
1. Never use elastic materials for elements of a tow system - even if you have read the lunacy Donnell published in the Eighties or...
Material should be a no-stretch line like perlon, spectra, or a particular 900-pound test like I found at a skydiving supply house.
...on Peter's website.
2. The weak link protects the release system from overloading. The release system is part of the aircraft. The definition is solid.
1. If it's too strong how can it "easily break"?
2. What G rating can you use to ensure that a glider can't pass VNE? Weak links tend not to break when gliders are going fast - they're most likely to break when they're doing the precise opposite.
Peter Birren - 2008/10/27
Imagine if you will, just coming off the cart and center punching a thermal which takes you instantly straight up while the tug is still on the ground. Know what happens? VERY high towline forces and an over-the-top lockout. You'll have both hands on the basetube pulling it well past your knees but the glider doesn't come down and still the weaklink doesn't break (.8G). So you pull whatever release you have but the one hand still on the basetube isn't enough to hold the nose down and you pop up and over into an unplanned semi-loop. Been there, done that... at maybe 200 feet agl.
3. Name a G rating you can use to prevent a pitch-up beyond the pilot's ability to prevent the start of a loop or break stall, tuck, tumble, and collapse.
Think about it, dude. Gliders pitch-up beyond the pilot's ability to prevent the start of a loop or stall, tuck, tumble, and collapse just fine in free flight. How are you gonna use a weak link to prevent bad stuff from happening on and/or just off tow?
The weak links' maximum breaking strength should not be so high that it is beyond the pilots ability to prevent a stall when it separates.
http://www.youtube.com/watch?v=vb4nUTAJXTk
http://www.youtube.com/watch?v=bTa6XL16i0U
http://www.youtube.com/watch?v=JR_4jKLqrus
http://www.youtube.com/watch?v=eTKIAvqd7GI
Peter Birren - 2005/02/08
This scenario is in my opinion what happened with Mike Haas at Cushing Field last year. His weaklink broke at a low altitude and he rolled off the stall.
Same weak link, similar G ratings.
ANY WEAK LINK CAPABLE OF GETTING SOMEONE AIRBORNE IS CAPABLE OF KILLING HIM EITHER BECAUSE IT BLOWS OR BECAUSE IT DOESN'T.
No. The sole purpose of a weak link is to prevent overload and it makes no difference what angle the towline's pointed when that overload is being approached.
It most assuredly SHOULD NOT.
Manned Kiting
The Basic Handbook of Tow Launched Hang Gliding
Daniel F. Poynter
1974
"The greatest dangers are a rope break or a premature release." - Richard Johnson
That's never gonna stop being true. That especially didn't stop being true when Donnell decided to reinvent aviation and the laws of Newtonian physics and throw logic and common sense to the winds.
A glider on tow thirty feet over the runway is virtually always going and/or having the option to go UP. A glider thirty feet over the runway with a broken weak link is ALWAYS going DOWN - often very quickly and sometimes sideways.
There most certainly ARE times when it's better to be off tow than on but they are EXTREMELY rare and virtually always avoidable down in the kill zone. And that's a good thing 'cause if you allow yourself to get get in a critical situation down low there's a real good chance you're gonna be killed equally dead whether or not you get off tow. And if you're waiting around for the weak link to do the job you should've done with your release two seconds ago... GOOD FREAKIN' LUCK.
Should a tow stop for any reason like motor failure due to a multitude of causes, unintended release, line breaking, weak link break, stupidly pulling the release when the pilot meant to pull a zipper cord or VG cord...
With the possible exception of engine failure, every one of those issues is one hundred percent avoidable and inexcusable.
...you should now be in a situation where you haven't flown yourself into a corner.
Right, you SHOULDN'T be. But we're all human, lotsa times you've got someone on the other end of the string who's pathologically human, sometimes Ma Nature throws us really nasty curveballs, and s*** happens. And sometimes there are two or three other things going wrong at the same time and we really don't need two or three hundred pounds of thrust instantly and irreversibly removed from the equation at a time not of our choosing.
Yeah, you SHOULD.
1. But hang glider people don't have great records of landing safely even when they get to start planning what they're gonna do from a couple of thousand feet.
2. And it's a lot easier to go up without hurting yourself or bending something than it is to come down without hurting yourself or bending something.
3. A landing following an engine, towline, or weak link failure is - by FAA definition - an EMERGENCY LANDING. And we can expect to see a lot more bad things happening in emergency landings than in vanilla ones. And, in fact, we DO - no ands, ifs, or buts.
Not down wind...
Winds shift - especially in really good soaring conditions.
...on a nude sunbather...
That one needs more consideration. I'll get back to you.
...on the dolly...
Shane Nestle - 2010/09/17
So far I've only had negative experiences with weak links. One broke while aerotowing just as I was coming off the cart. Flared immediately and put my feet down only to find the cart still directly below me. My leg went through the two front parallel bars forcing me to let the glider drop onto the control frame in order to prevent my leg from being snapped.
...into the electrical sub station...
You don't need to come down into any of that stuff to hurt or kill yourself. A nice soft grass strip will do the job just fine.
Keith Skiles - 2011/06/02
I witnessed the one at Lookout. It was pretty ugly. Low angle of attack, too much speed and flew off the cart like a rocket until the weak link broke, she stalled and it turned back towards the ground.
And someone who may not be launching perfectly doesn't deserve to be punished for a flawed launch technique on a single occasion by getting the crap beaten out of her.
Davis Straub - 2005/01/13
Tom Lanning had four launches, and two broken weaklinks and a broken base tube.
And I know Tom and like him a lot. And he's a competition pilot and - aside from allowing himself to be brainwashed and/or bullied by SCUM like Davis into using 130 pound Greenspot - knows what he's doing. And if you're blowing three quarter G weak links every other other tow 'cause they can't handle world class thermal conditions in Australia you WILL crash a lot of gliders and do a lot of damage for NO REASON beyond trying to use the weak link for something other than the only job it can safely do.
Postby Bill Cummings » Wed Dec 07, 2011 6:46 pm
Well, that was not as painful as I thought it might be. :D
It would appear so far that the opinion that I hold concerning weak links is the single deviation in towing protocol that I have with Tad’s towing procedures. Whether I am right or wrong is not my overriding concern here. What is right or wrong is the greater issue.
Readers can check out both of our posts and go away with perhaps an aspect of weak links that they had not yet considered.
Thanks Tad for your response and input to my post. :thumbup:
Postby TadEareckson » Thu Dec 08, 2011 4:03 pm
Yeah, I've been a bit nastied out lately from dealing Sam, Terry, Peter, and Rick.
It would appear so far that the opinion that I hold concerning weak links is the single deviation in towing protocol that I have with Tad's towing procedures.
As far as theory is concerned we're light years apart - based on your previous post anyway. But with respect to specifications/implementation we're only off by 0.2 Gs.
Hopefully when a correct determination of what is right is reached you'll make whatever adjustments are necessary for you to also be right. And the right answer here is pretty obvious - all ya gotta do is read the accounts, watch the videos, and do the math.
And thanks for participating in a dialogue.
Peter Birren - 2011/11/29
Yup, Don's 12 points are as good today as they were when he wrote 'em... and you're benefiting from his being the first to establish towing guidelines and considerations.
We need to get a critical mass of people who understand that Donnell's takes on the physics of hang glider towing were ABSOLUTELY CLUELESS ROT and his approaches to it were were disastrous. One could write several books on what he got totally backwards and what the consequences were - and are.
Bill Cummings - 2011/12/07
Donnell Hewett - 1981/04
It should be obvious that any type of stretching device of sufficient stretch at the required tension could be used, including a spring, elastic band (surgical tubing), bungie cord, or the natural stretch of a nylon towline. Regular parachute shroud line (1/8 inch nylon cord) of rated breaking strength near 800 lbs will stretch about 10% under about 150 lb pull. This means that anything over 300 ft of line will provide the 30+ ft of needed stretch. At 3 cents per foot, this amounts to less than $10.00 for a reliable and smoothly variable tension controlling device. It's hard to imagine a more reliable, more compact, more portable, or more cost effective tension regulator than this, so until one comes along, we will continue to use it in our skyting applications.
Donnell Hewett - 1985/04
And concerning the three other USA fatalities - those involving beginner/novices and apparent lockouts - I would like to know what these inexperienced pilots were doing at altitudes high enough to lockout? Were they being pulled so fast that a lockout which started at only 3 to 6 ft forced them into an arc high enough to roll over? If so, why were they being pulled so fast? What strength of weak link were they using that it didn't break when being pulled that fast?
We need to start understanding that we've got a thing called a PILOT in a tow system and that's the only component of the glider end of the system that can keep the glider at proper pitch and roll attitudes and make the decisions about when to remain on tow and when to abort. And if pilots aren't properly equipped to be able to abort while maintaining what pitch and roll control the situation allows we can expect to kill a few when the s*** hits the fan at low altitudes.
We also need to understand that the person on the other end of the tow system is a copilot controlling the glider's thrust and he can make the difference between life and death when the s*** hits the fan at low altitude.
And there's no freakin' way you can use a piece of string which breaks at a predetermined number of pounds to keep a flight under safe control - and one would think that three decades worth of crashes, injuries, and fatalities following variously rated weak links blowing and holding at inconvenient times would've made that pretty clear by now.
Postby Bob Kuczewski » Fri Dec 09, 2011 3:30 pm
Hi Tad and Bill,
As I mentioned in the other topic, I've decided to "do the experiment" to determine if Tad's postings are hurting or helping the US Hawks. To make that determination, I've restricting Tad to the "Free Speech Zone". So if you'd like to continue the conversation there, please feel free to do so and post the name of that topic here (along with a link) so people can continue to follow the conversation.
My restriction of Tad to the Free Speech Zone isn't intended as a judgement of his ideas, but as a response to his assertion that his postings are helping to grow the US Hawks. I hope everyone who's enjoyed corresponding with Tad will continue to do so in the Free Speech Zone.
Thanks, and I'm sorry for any inconvenience.
Users browsing this forum: Bill Cummings and 32 guests
