Some Atos skids
Notice that some shrubs and grasses could still whip wrap the basebar.
The pioneer years of aviation included both successful and misguided efforts to make the number of safe landings approximate to the number of takeoffs. Here are some notable examples on both sides of that record.
From Safety Corner at SHGA wrote:Landing: What Matters Most?
Answer: how you hit the ground.
OK, so what's second most important?
The final leg of the approach sets up how you'll hit the ground. Consider that everything leading up to the final -- including LZ inspection, runway selection, staging, downwind leg, base leg -- can be custom designed to set up an ideal final for an ideal touch-down in the conditions. Are you noticing the crab angle of your glider on downwind and base legs? Are you adjusting the length of your base leg while on downwind for sink/lift/wind encountered, to still arrive at the top of an ideal final leg? Each leg of an approach increases in importance, because the options naturally reduce.
Everything in service to an ideal Final, which is in service to an ideal touch-down.
Users browsing this forum: No registered users and 81 guests
