Hawks,
A word of caution when employing the “Trim + one second” flare technique. Jim Rooney made a point to mention that this will work with any stock glider. This means to me that the trim speed (Hands off, neither pushing or pulling on the control frame) is at the correct speed as it comes from the factory test pilots.
I would think the type of harness used could affect what you think is trim speed while upright for landing. (hands on the down tubes.)
My harness allows me to have a very light touch on the down tubes while my body position is vertical for landing.
Other harnesses’ that I have tried have required me to put a lot of down force on the down tubes just to remain vertical. This has the effect of moving your cg (center of gravity) forward.
I would bet this would have you flying a little faster while you are feeling for the trim speed. (neither pushing or pulling on the control frame.)
So maybe trim + two seconds before flaring would work in this case.
I really don’t know for sure. Does anyone else have that part figured out?
Just on a guess if your harness fights you getting and staying vertical and you try the “trim + 1” and you start to balloon when you flare, the trim + 2 is what I would try next.
