Davis and Jack: 'Conflict of Interest' Criminals
Postby Free » Fri Feb 25, 2011 1:27 pm
A discussion on barrel release failures ensues on the censored web forum http://www.hanggliding.org/viewtopic.php?t=21033
It is sad that the site owner Jack Axaopoulos, limits the discussion to the lowest common denominator of his fragile ego, fears and commercial self interest.
Truth is denied on Jack's site.
Jack can't handle the truth..
Jack Axaopoulos, (Band of Brothers) may be responsible for the next pilot to die from a jammed up barrel release.
As I sit here going thru the motions in my head, it shouldn't take more than 4 or 5 seconds to grab the rope and pull. That is if you have a little trouble finding it. My barrels are also on a short leash so they stay pretty close to the same place regardless if being pulled forwards or draping backwards. That way I can find them easy enough.
The barrels I have are VERY hard to pull... there is no way even a full length tow rope is going to offer enough resistance to make the barrel release.
I did hear about a double-way release barrel a couple of years ago. You can push or pull the barrel to release. Not sure who makes them or if they are available but it would solve the problem.
There are a bunch of different barrel releases. Some have thicker webbing, some thinner, some have bigger barrels bent pins, straight pins, etc...etc...
So some may, and some may not release. As I mentioned, assume they won't and it'll only take you a few seconds to drop the line.
Free
Re: Davis Straub's "Oz Report" Conflict of Interest
Postby TadEareckson » Sun Feb 27, 2011 7:34 pm
http://www.hanggliding.org/viewtopic.php?t=17404
Holger Selover-Stephan - 2010/05/28
Portland, Oregon
Aerotow barrel release - straight or curved pin?
I ordered and received a few barrel releases from Blue Sky. They have straight pins, not the curved ones I'm used to. Steve at Blue Sky tells me this:
...they [the curved pins] don't release with as little tension on them as the straight pins. Otherwise, there is no difference. It makes it hard to put just a rope on the barrel end, which encourages a weak link. Just a good idea. That's why we've been shifting that way, as are many other manufacturers of these releases.
Anybody got an opinion on this matter? Thanks!
OF COURSE THEY DO, Holger. This is the Jack Show. NOTHING BUT OPINIONS!!! When you've got a whole worldwide organization controlled by someone with total shitt for brains catering to people like you with total shitt for brains, opinions is all ya have to work with. So each participant has got at least a dozen of them to compensate. That way when one of his opinions gets blown out of the sky - figuratively or literally - he's got at least eleven backups (providing that if it's literal his parachute opens in time).
peanuts
i've tried both and the straight is easier to release. for some reason, it was also easier to improperly load/arm
Yeah peanuts, for some asshole who's never been able to get a solid grasp of the shift key it's pretty easy to phuck up damn near anything.
Holger
Thanks, peanuts. How do you improperly load the straight pin barrel?
Lemme take this one peenuts...
You find the stupidest person on the planet, hand it to him, duplicate his actions, and never once think or check it on the ground before you take it up.
Also, which style do you like better?
For functionality I'd hafta go with the straight. But you're more interested in STYLE. And for style a curve is just so much more elegant than a boring old straight pin.
tipvortex
New Jersey
Where's AeroTow?
Right here, Tip! At your service!
Holger
Uh? Not gettn it
Oh Holger... Those 193 magic days in 2009. And already you've forgotten me? Oh well, with a brain the size of a walnut I suppose there's only so much information you can store and still be able to do the essentials like differentiating the bathroom from hall closet. We certainly don't wanna have that problem ever again.
Bob Flynn
Jacksonville, North Carolina
I've only used the curve pin so I can't say one way or the other. BlueSky does alot of towing though, (scooter, truck and aero) so I have to put give some credit to their opinion.
H2 - AT, FL, CL, FSL
Horizon ET 180/Z3 Pod/Yaesu 270 comm
Right Bob. If someone does the same thing over and over the same way for decades on end he surely must know what he's doing. And, as far as I know, Steve's only sent one his students to shock trauma with one of those things.
Prior USAF and damn proud of it.
Yeah, if only the Academy were more of an engineering school and less of a testosterone poisoned fundamentalist Christian cult.
Good Judgement comes from Wisdom, Wisdom comes from Bad Judgement
So how do you explain Bo Hagewood, Jim Rooney, Lauren Tjaden, and Bart Weghorst?
When Jim got me locked out to the right, I couldn't keep the pitch of the glider with one hand for more than a second (the pressure was a zillion pounds, more or less), but the F'ing release slid around when I tried to hit it. The barrel release wouldn't work because we had too much pressure on it.
Anyhow, the tandem can indeed perform big wingovers, as I demonstrated when I finally got separated from the tug.
And at Quest they only jam up high and up high nothing's ever a BFD.
Holger
Thanks, Bob! They're probably find, but I'm still on the fence since I know the others are tried and work.
Yeah, Holger, they PROBABLY are FIND. I mean, fifteen thousand aerotow instructors and pilots mindlessly aping each other for twenty years couldn't possibly all be wrong about something, could they?
peanuts
what i was referring to was that for some reason, sometimes people didn't get the pin BETWEEN the lines (normal), and instead got it beside the loop.
Really? Is there a single recorded instance of anybody doing this? Or is it like the guy bolting the JATO unit to the top of his Chevy Impala and lighting it off in the Arizona desert? (bulls***.)
also check the release (the one we're talking about) to make sure it is engaged before signaling to initiate launch sequence. the straight pin would sometimes just slip open by itself. but that was Aerotow's itteration. don't know if i have seen Steve's yet.
No, that wasn't AeroTow's "itteration" you freakin' asshole. This is Aerotow's iteration:
http://www.flickr.com/photos/aerotowrelease/2797915482/
That little stitched-in hump provides the light resistance inside the barrel to prevent it accidentally opening before launch.
as to who/what an "Aerotow" is, he was a dangle kite jumper with a SEVERE case of OCD and myopia who made BobK appear to be a wallflower. his posts would go on for months repeating hisself, convinced his was the only way.
Yeah, it would be so nice if you could just say two-plus-two-equals-four ONCE and move on to addressing the next issue for you eternal fuckups but the stupidity is something I never imagined would be possible.
also rube goldberg incarnate. the straight pin was the only simple/pure advocacy he had...
Zack C - 2011/01/10
When I first saw your release years ago on the Oz Report forum my impression was the same as most people's. I didn't know what the pictures were showing but it looked way more complicated than it needed to be. After seeing the problems that even the best releases on the market have and learning more about your release, however, I understand why you made it the way you did and the advantages it provides.
...if it was indeed his.
No, if you bozos ever get your shitt together enough to understand grade school science it will have been Jim Rooney's. He's the guy who told Wilbur and Orville that they needed a rudder to deal with adverse yaw. Just ask him.
Ryan Voight - 2010/05/29
Point of the Mountain
as to who/what an "Aerotow" is...
Funny, but also very true...
Hey Ryan, ya know what I think is pretty funny? "Instructors" like you telling knuckle draggers like Holger:
It works best in a lockout situation... if you're banked away from the tug and have the bar back by your belly button... let it out. Glider will pitch up, break weaklink, and you fly away.
Have you never pondered what you would do in a situation where you CAN'T LET GO to release? I'd purposefully break the weaklink, as described above. Instant hands free release.
'cause some of them are likely to actually do it. Then things start looking up for the gene pool - especially if they do it while they're up with you on a tandem lesson.
His username on here was "Aerotow", FYI. He also took it upon himself to contact the FAA and provide them with a report stating that the USHPA's aerotowing practices were utterly unsafe and people were getting hurt left and right
Yeah? Did any of you a**holes take the time to actually READ what I said? That's a rhetorical question 'cause I know damned well none of you has the attention span to get through through a whole paragraph - even with three or four smilies to break up the tedium a bit.
Lucky for us the FAA knew what to do with him.... IGNORE and disregard...
Yep. That's how come Shane got killed a state to the south of you last month.
Holger - 2010/05/29
Thanks, guys. Yeah, tipvortex clued me in with a PM. I forgot that was Tad's alias here.
It wasn't an "alias" Holger. The forum wouldn't let me register under my own name - like I have on everything else I've ever been on. You want aliases? peanuts, tipvortex, thefly257, hgnv...
After a while I just ignored all his preaching...
GOOD. I'd really hate to see the control group get much smaller. And, again, the gene pool...
...and just hoped the FAA would do the same.
Yeah. Time will tell how that works out for them.
Looks like the straight pin would be OK.
Oh, do ya think? How's the bent one LOOK? Has it ever occurred to you to actually TEST it? (Rhetorical question.)
I may still send the 6 I ordered back to Blue Sky. The barrels vary in length between 35mm and 50mm and there isn't a twist to lay the webbing flat in the Lark's Head knot. Also the webbing is bulkier then needed.
Yeah, Steve always has been one for overbuilt, underpowered crap.
The manufacturing seems a little sloppy, unfortunately.
SEEMS? Even to you?
axo
M111S Aerolite Stainless Steel Straight Release Pin
http://www.paragear.com/templates/base_ ... p=29#M111S
Aeros Target 13
H2 - AT
Holger - 2010/05/29 17:22
3 thumbs up
Holger
2010/05/29 17:25
Wow, awesome! Thanks a lot, ax'!
Yeah! AWESOME. Ask him who PMed him that link eleven months prior. (Thanks a lot for sticking up for me, Axel.)
Jim Rooney - 2010/05/30
I'll leave ya'll to any discussions about the merits of the pins, but the way you incorrectly load the straight pin ones....
It has ABSOLUTELY NOTHING to do with straight versus curved - you moron. It's a function of the thickness of the webbing.
Rotate the pin sideways instead of the correct way... so if we're talking about the one in the picture... instead of rotating it as shown, with the tip of the pin sliding on the table, pick the tip up towards you and flop it over towards the barrel.
Your line can now trap itself between the big round base and the webbing, locking it. (it will not release).
Preventing this scenario is likely why he's using such thick webbing.
If the insanely thick webbing prevents an insanely stupid "pilot" from this insanely stupid scenario (and you're calling a "scenario" 'cause it's never actually happened) why are we even talking about pin shape in this context?
Holger
Ah, so an incorrectly loaded barrel would not have the pin sandwiched between the webbing. Instead it will lay on top of both layers of webbing. I see how that can snag upon release.
It isn't a case of it SNAGGING - you moron. It's LOCKED ON.
Makes sense to use a thick webbing to prevent this from happening. I'll try and sew two webbings together with a more flexible one towards the harness. Thanks, Jim. That was helpful! So you don't have a preference for either pin?
Who the phuck cares about his idiotic "PREFERENCES"?
Jim Rooney
Toma-y-to Toma-h-to
Back when Tad had his panties in a bunch, I decided to test things myself... it's easy to do... have a blast...
I took a single barrel release and hung it from the ceiling. I made a loop in a rope that allowed me to put my foot in the rope and be suspended an inch above the floor.
I opened the release.
Both open fine.
Curved pin was a little stiffer.
I filed it under Big Fing Deal.
Bart Weghorst - 2011/02/25
Jackson Hole
But I've had it once where the pin had bent inside the barrel from excessive tow force. My weaklink was still intact. The tug pilot's weaklink broke so I had the rope. I had to use two hands to get the pin out of the barrel.
Jim Rooney
I routinely use curved pin barrels to D-Bag.
GOOD (DBag).
Holger
Thanks, Jim. It's all tomatoes to you because you know this stuff.
Mitch Shipley - 2011/01/31
Enjoy your posts, as always, and find your comments solid, based on hundreds of hours / tows of experience and backed up by a keen intellect/knowledge of the issues when it comes to most things in general and hang gliding AT/Towing in particular. Wanted to go on record in case anyone reading wanted to know one persons comments they should give weight to.
Yeah. Keen intellect.
I'm new at this and thankful for the advice.
And I'm thankful you're taking that advice, Holger. And don't worry about being "new". You'll still be just as unbelievably clueless when your bent pin jams and you slam in at the end of that nightmare scenario people like you are so sure will never happen.
Jim
No worries Holger.
Sorry if it sounded like any of that was directed at you.
That's OK, Jim. I've got him covered.
BTW, Steve is exceptionally knowledgeable. Hell, he's the one that signed off my instructor rating.
Figures. One dangerous fu**ing idiot signing off another dangerous fu**ing idiot. Two of his students launch unhooked within 143 days of each other. One gets killed and you just barely survive. (Real bitch the way that worked out.)
Anyway, he doesn't sell junk.
Scott Wilkinson - 2005/05/29
As Ralph mentioned, I didn't see Holly's accident, but Steve Wendt (Blue Sky Hang Gliding - Manquin, Virginia) saw it all (as did several others). For now, all I'm comfortable saying is that Holly opted to aerotow on her Moyes Litesport (one point - Bailey). From what Steve told me, she experienced oscillations shortly after takeoff which quickly became severe. At an altitude somewhere between fifty and a hundred feet (we don't know for sure) there was a lockout situation with the glider at a near ninety degree angle. When a line broke (I don't know which one), Holly's glider recoiled backwards, almost fully inverted, then partially recovered in a dive toward the ground.
Steve saw Holly pulling in for speed. He speculated had she been ten to twenty feet higher, she might have made it... and ten to twenty feet lower, she could have died. Whatever the case, she hit the ground hard at something less than a vertical angle. Her Charley Insider full-face helmet was broken through in two places (the chin and next to her eye), and Steve believes the breaks absorbed some of the impact and probably saved her life.
Nah. Course not.
If he's selling it, he likes it.
Yeah. And if a dealer is using the crystal meth he's selling - what more do you need to know?
That goes a long way in my book ;)
Yeah.
The United States Hang Gliding and Paragliding Association, Inc.
Standard Operating Procedure
12. Rating System
02. Pilot Proficiency System
10. Hang Gliding Aerotow Ratings
-B. Aero Vehicle Requirements
06. A release must be placed at the hang glider end of the tow line within easy reach of the pilot. This release shall be operational with zero tow line force up to twice the rated breaking strength of the weak link.
What do we even need standards for? If some skinny little asshole can pry the thing loose and drop himself from a tree AND STEVE LIKES IT - what more do we need? Why don't we do gliders the same way? I flew it down a training hill once and it didn't fall apart or tuck AND STEVE LIKES IT... Look out eBay - here I come!!!
bobk
San Diego
Proof that everything is relative.
However, it's a little unfair to label the combination of "focus" and "drive" (both good qualities) as "OCD" and "myopia" (both pathologies). I think Tad has both focus and drive, and so did many aviation pioneers (and pioneers in many other areas) who have improved our lives.
They say "it takes all kinds", and indeed that's true [spoken as Bob steps down from his soap box]. Carry on gentlemen.
Bob Kuczewski: H4/P4 - Torrey Hawks, CSS, SHGA, E-Team, Soboba Soaring
Learn to fly hang gliders - Join the Torrey Hawks - Fly the Big O Loop!!
"Hang Gliding must be represented by an organization that cannot survive without it" - gs
Paul Hurless
Reno
Tad was way beyond "focus and drive".
And what the hell would some waste of space like you know about either focus or drive? You never had an original thought in your entire life and never will. Somebody handed you a wrench and said, "Turn this. And that's exactly where you hit your limit.
bobk
To be honest, that's hard for me to say for sure in this case. But the topic did come up when I was on the Board, and the first reaction by some "leaders" in USHPA was to call the USHPA lawyer to muzzle him with a nasty letter. As a Board member I argued against that approach because I felt that it would be better to open lines of communication rather than shut them with legal threats. Fortunately, cooler heads prevailed and some of the Directors who knew him were called in to help.
It wasn't fortunate for Shane. Probably didn't do Lemmy Lopez a whole lotta good either.
As far as I know, things were resolved peacefully without further escalation.
Oh no. Two things were "resolved". USHGA decided it was totally cool with continuing to kill one per thousand per year in unbelievably stupid Shane Smith scenarios. I resolved that I would never again negotiate with those sleazy incompetent bastards and I will take any opportunity I can to do them as much damage as I possibly can for as long as I am physically able.
My biggest point is that someone like Tad (and even myself) has a tremendous amount of energy because they believe in their cause. It's far better (and wiser) for USHPA to work with that energy and to channel it rather than to beat their head against it. In my experience, they tend to reach for their lawyer waaaay too soon, and that just creates hard feelings.
Yep. Damn right it does. And they've just got one lawyer. And his understanding of aviation OBVIOUSLY sucks even worse than theirs does. 'Cause if it didn't he'd have actually read my letter and been so terrified of the way his scumbag client is behaving that he'd have done something about it and I'd have seen some positive change. But this guy's obviously a total moron too.
And they kill about ten people a year and seriously injure a lot more - most of which we don't hear about 'cause all of the effort they should be putting into reform goes into cover-up.
But I can educate the attorneys of victims and surviving family members to keep him real busy. Then dues might go up 'cause I might be able to launch a big enough attack to keep ten lawyers real busy.
And they're gonna lose. So insurance rates are gonna skyrocket, dues will go higher, membership will drop, and flight parks will find it a lot harder to do anything beyond one time thrill riders.
The same thing happened when USHPA got upset with Davis for posting a link to the USHPA web site, and I'm sure there have been other examples as well.
I'm sorry, I really didn't want to derail this topic since I've never towed, and I don't know much about towing at all. But I think USHPA needs to figure out how to bring our resources (people) together rather than threatening them and tearing them apart.
Way, way, way too late.
thefly257 - 2010/05/31
Orlando
I manufacture releases and have always used curved pins.
Yeah. Everybody and his freakin' dog MANUFACTURES releases. But nobody has any brains and nobody actually
TESTS them before endangering or ending people's lives on them.
I looked into using straight ones but it seems the curved ones had a couple of benefits I personally liked.
Oh. It SEEMS that the bent ones have a couple of benefits. And you "personally" LIKE them. WOW!!! You like them, Steve likes them, Jim, Bart, Paul, Lauren, Adam, Bo, Matt, Tracy, Malcolm, Bobby... EVERYBODY LIKES THEM. Nobody DOESN'T like them. So mission critical aviation equipment is just one giant popularity contest. Phuck standards. Let's put them in the air the same way we narrow things down for American Idol.
One, there was a little more friction that helped with accidental release prevention and also, the release was actually quicker.
The friction is a function of the thickness of the webbing - not the shape of the pin - you idiot.
With a straight pin, the release doesn't happen until the tip of the straight pin completely passes out of the aluminum tube.
Whereas with the bent pin it releases BEFORE you clear the tip.
With a curved pin, once the apex of the curve passes out of the tube, the force on the pin aids in the release.
Does it? Have you TESTED that? Did you find out if, in fact, the case is the precise opposite?
http://www.flickr.com/photos/aerotowrel ... 066212198/
(Rhetorical question. Don't talk to me - life is too short as it is.)
Holger
Certainly does. Good to hear about Steve. I didn't mean to say it was junk I received from him.
Well then, lemme help you out some. It was shitt.
Nonetheless I'd say it was on the sloppy side and for aviation gear I like it on the mark.
OK, won't argue against that. Make it sloppy shitt.
Dan Tomlinson - 2005/05/30
Tad's post is difficult to read but I've seen his work. His release mechanism is elegant in its simplicity and effectiveness.
Hugh McElrath - 2005/03/05
Thanks, Tad. I was too green to fully appreciate your system when you showed it to me a couple of years ago. Now I'm more interested. Do I have to fabricate this myself from parts or are you in business?
Janni Papakrivos - 2008/06/30
Tad showed me the release system he installed in Hugh's glider. I was amazed at the quality and complexity of the system. Being able to tow and release without ever having to take your hands off the base tube is wonderful and much safer.
Patrick Halfhill - 2009/06/21
You and I met at the ECC a few years ago. We spent 45 minutes or more together going over your system. I saw it first hand. I was quite impressed with the quality of engineering and the time you spent on it.
Windlord - 2009/05/03
Very nice engineering, Tad. I can see a lot of thought went into the systems and there is always room to "build a better mousetrap".
Since this is a public forum and I don't want to make unfounded critical comments about a HG supplier...
No Holger, you REALLY don't wanna say anything critical about a USHGA Made Man. Not if you ever again wanna fly at a US tow park or speak on a large public forum. And you're never gonna be welcome on mine and if you come over here I'll rip your a** to shreds.
...let's file it under ignorant, anal customer expectations.
Yeah, let's do that. When someone even as stupid as you are recognizes the shoddiness of what's available from the Flight Park Mafia it should be pretty obvious to the just normally stupid glider crowd that we're never gonna get anything without good standards and enforcement.
Go back and READ (I know, never one of your strong points (assuming you have any)) what he said. He's just speculating.
That's exactly the information I was looking for. Appreciate it, thanks for sharing.
That's not INFORMATION. That's some anonymous, unidentifiable idiot's clueless OPINION. By the way how are things going at http://www.chemtrails911.com?
I've ordered straight and curved release pins from ParaGear and will make a few releases to try it out.
By which you obviously mean take it up and fly it. Bench testing? (Rhetorical question.)
Sam Kellner - 2010/06/01
Leakey, Texas
With curved pins, attention to detail must be taken when folding the pin.
Normally the pin is folded back into the loop, tip first.
If the curved pin is folded improperly, and tucked back into the loop apex first, the tip of the pin can snag one side of the loop.
In this configuration, it will not release even if the barrel is clear.
Sorry no pic right now.
Ya know Sam, gliders used to have straight battens. Didn't matter which end you stuck in first or which side was up. Then gliders started coming with curved battens but there weren't any thirty page discussions about the dangers of inserting them backwards or upside down and nobody was stupid enough to do it.
Jim Gaar - 2010/06/01
Kansas City (Roeland Park)
Always curved here Holger. Hundreds of clean, no snag releases in both pro-tow and v bridle setups among 4-5 different pilots.
SUPER, Jim. HUNDREDS of tows!!! 130 pound Greenspot. NO PROBLEMS!!!
Why don't we just do passenger jets that way? Five planes with five pilots, each one does a hundred flights with passengers loaded in smooth air between Logan and JFK and if nobody goes down in flames we can skip all that burdensome big government airworthiness bulls***. And if planes start going down in flames after that we can just keep focusing on the good stuff.
Oh wait. The barrel release virtually never comes into play when you're towing two point so let's knock it down to a hundred flights. Way more than enough.
Jim Rooney - 2010/06/02
Here's how to foul a curved pin release. And how to fix it.
To foul it, you have to load it backwards through the webbing and lock it on one side. Putting a stitch where my fingers are pinching eliminates the problem as you can no longer rotate between the webbing.
You mean like the way I showed you and the rest of those DC area a**holes three years ago?
http://www.flickr.com/photos/aerotowrel ... 61/detail/
What a total sleazeball you are, Jim.
Straight pin releases are far easier to foul.
bulls***.
I'll see if I can get pictures of how... gotta see if I've got one hanging around.
Media BLOCKED
Media BLOCKED
Media BLOCKED
PilotGuy
2010/06/02 18:56
3 thumbs up
Holger
Good stuff, Jim. The photos really make it clear. I'll sew a seam in where you indicated it. Makes a lot of sense.
Thanks!
You're welcome, Holger.
(Mike, is this the same way the BHGA scumbags wrote you guys out of the history books?)
hgnv
Las Vegas
Nice visual Jim... really clears it up... Thanks
"Nobody Plans to Fail.... Many just Fail to Plan"
Airborne Sting II xc
H-3 FL, FSL, CL, AT
Don't mention it, whoever the hell you are.
Jason Rogers - 2010/06/03
Port Macquarie, New South Wales
I've got a lot of time and sympathy for Tad.
I'm the "AeroTow" of the world of rebreathers. I knew a lot about them and when they became commercially available. I did a lot of hand waving about training, procedures, and design. I predicted death rates as high as ten percent of users per year.
As it turned out the death rate was no more than about one to two percent per year. Well the first year it was probably ten but then things did settle down.
Eventually I came to my senses and walked away from the whole thing, but it wasn't easy. A friend who refused to implement the solutions I advocated had horrible decompression accident and friends of friends died all the time. I blamed myself for not having pestered them enough to do things the way I thought they should have been done.
It was all a bit difficult. I would be tempted to shut up, then I would think that this one post might make the difference that would mean I wouldn't have to attend another funeral.
Now towing is clearly a lot safer than rebreather diving per event. But I can still understand where he's coming from.
Intermediate, Moyes Mars 170, Moyes GTR 162, Airborne Fun 190, Airborne Sting 168, Mosquito NRG
I reckon anything advertised below this line must be bloody good (unless it's paraglding)
bobk
2010/06/03 08:01
3 thumbs up
And... End of thread. (Probably used too many three syllable words and frightened everyone away.)
Holger,
http://www.flickr.com/photos/offcenter/122432026/
I'm gonna post that link for your many friends when they announce your little "celebration of life" get-together. Maybe someone can chisel those idiot comments on your tombstone.
Postby Free » Mon Feb 28, 2011 8:57 pm
But we ARE roasting the planet
A lot of people disagree that *we* have that much effect on the weather.
If you are talking about real pollution and the poisoning of the planet, not the life giving CO2, then I have to agree that humans have a lot of room to clean up their act.
and it terrifies and depresses me.
Then the years of conditioning and propaganda is having the desired effect from those that would enslave you.
Good intentioned people are manipulated and made to hate themselves for killing all the polar bears. Al Gore is a big fat liar intent on plundering the masses while he flits around the globe in private jets and limos, humping the hired help like a dog in heat.
'Poison' CO2 was an idea that came out of the globalist Club of Rome in the 60s as a plan to control the world.
We ARE seeing mass extinction NOW
Yes, the real industrial/chemical poisons are slow killing the dumbed down masses by the millions.
Most people are so indoctrinated that they continue to allow this to happen even though the truth is in black and white right before their eyes. Mass medication with fluoride in the water is the proof of sheep like ignorance of the American public.
Tad, I'll challenge you and everyone here to just take roughly the same amount of time that it takes to review and consider the issues and operational differences between curved and straight pin releases and apply that amount of time researching the pros and cons of mass dosing our water supplies with the toxic waste fluorosilicic acid.
There are no fuzzy math or theoretical computer models here that tell you that the earth is going to melt or freeze.. again, generations down the pike if we don't start paying a breathing tax to the likes of Al Gore.
One simple poison that is proven, here and now. The effects are here and now and where is the uproar?
Maybe there is no uproar beacuse one of the effects of this poison is that it makes us docile and dumbs us down.
Safe releases? Sure.. why not?
Safe water? That's crazy talk, eh?
Crazy to ignore.
http://www.fluoridealert.org/
Were you Freedomspyder a couple of years ago?
Nope. 'Free' is derived from FreeUSHGA, as in a plan of hang gliding growth.
It was my old idea of helping set some deserving young hang gliding instructor up with as much equipment and infrastructure as possible to help them get a hg training business off the ground.
The only growth in hg has to come through a willing instructor and it seemed that there had to be some willing to teach that couldn't because of lack of resources to get started. There are many places like Kansas City with no real instruction. I've pissed away a lot of money, time and effort over the years on tools that would help others get airtime.. towrigs, tugs and thieving flight park partners but no good deed goes unpunished and I guess I've written the idea off. Free USHGA could just be an idea that died on the vine.
Now I'm one that just wants to be free on this poisoned prison planet.
Free
Postby Bob Kuczewski » Tue Mar 01, 2011 1:30 am
Tad,
They say that the best revenge is living well ...
Jack and Davis both have histories of being unfair to people they didn't like. Let's do better here on this site. Let's do the things that will make people want to come here and be part of this community. Let's build better standards for towing. Let's build a better framework for an organization. Let's do what we think is correct and just.
That's why I built this site. It's certainly a place where we can point out the foibles of others, but it must also be a place where we build a better future of our own. I hope you'll help.
Re:
Postby Bob Kuczewski » Tue Mar 01, 2011 1:40 am
It's not dead yet. I hope the US Hawks will be the "Free USHGA" that you imagined. I hope to come out to visit you in the spring and bring Little Hawk. Maybe we can drum up some local interest in the sport and get the "Mo Hawks" going. :thumbup:
Speaking of visiting ... where do you live Tad? It would be good to meet you in person as well.
Re: Re:
Postby Free » Wed Mar 02, 2011 11:58 am
bobk wrote:I hope the US Hawks will be the "Free USHGA" that you imagined.
My idea has morphed over time into something much bigger than anything I can do by myself.
Now, I think more of a 'ground up' National Instructors' organization that could eventually overtake the parasitic U$HPA corporation that now rules 'top down' without accountability.
The future of hang gliding is nothing without instructors.
The borg corporation is nothing without instructors.
The lifeblood of hang gliding hinges on the work of instructors.
All new pilots are filtered through instructors.
There is a bond that forms with pilots and their instructors.
The borg doesn't instruct. The corporate lawyer doesn't instruct.
They rule from the safety of their board room secrecy and merely feed off the work and risk of instructors.
The lowly instructors don't realize they are actually in the driver's seat.
Instead of passively waiting for edicts and direction to be handed down from on high of the corporate borg the instructors need to take the initiative and organize themselves.
Pilots would be behind them if they could get their act together.
My idea of assisting with equipment and infrastructure could be duplicated in other areas.
A 'ground up' organization can grow within the U$HPA corporation, using the group rate insurance while they are building an instructor's organization at the same time.
Every new pilot trained properly will have a natural affinity to those instructors that treated them with dignity and safety over that of the corporate borg that merely takes their money and scorns them.
Every new pilot would be dual members of the Instructors' organization and also the U$HPA.
At some point when the instructors get all their ducks all in a row they can shop their own insurance. They can have credibility with the FAA because their program of instruction will be equal or greater than the standards of the non-instructor borg corporation of the U$HPA.
Things are in such turmoil, geopolitically and economically, that I don't have much expectation of this ever happening but I thought I would toss it out and see who might bite on the idea.
Free
Postby Dennis » Mon Mar 07, 2011 5:55 pm
Wow, that was a read! A good one though.
I don't know squat about Aero Tow, so, I've got nothing "useful" to add. So, I think I'll sandbag it for a while and get educated.
Dennis D
HG, PG, it's all fun.
Crestline Soaring Society
Dennis
Postby TadEareckson » Tue Mar 08, 2011 5:25 pm
Sorry for the delay folks, lotsa stuff (relatively speaking) has been happening at Kite Strings lately and I've been pretty tied up over there.
Warren,
Yes. And since the overwhelming majority of people are idiots one should discount ENTIRELY from one's understanding of reality the OPINIONS of "a lot of people".
To protect ourselves from the opinions of a lot of people we have SCIENCE. Scientists use observations, evidence, data, mathematics, chemistry, controlled experiments, modeling, logic to understand how things work and make predictions. For example, a scientist - if given the air density, relative humidity, whatever - can tell you how long it will take a cannonball to hit the bottom of the Grand Canyon after you drop it from the side.
A lot of people in hang gliding - the OVERWHELMING MAJORITY in fact if the sample in:
http://www.hanggliding.org/viewtopic.php?p=145032
is representative of the population at large (which, based upon my thirty years of observation, it is) believe that 75 pounds is more than 75 pounds if applied quickly. So I really don't give a rat's a** what "a lot of people" agree or disagree with. You use the science to identify the morons, remove them from the engineering and policy making processes, and find jobs for them where they can operate at the upper limits of their potentials asking people if they'd like fries with whatever else their ordering.
Then you take the people that you DO want in the gene pool and use them to design the gliders, harnesses, parachutes, helmets, and tow equipment and write the owner's manuals and training procedures and requirements.
If you are talking about real pollution and the poisoning of the planet, not the life giving CO2...
CO2, like O2, is only life giving in the right place in the right amount. Screw it up a bit and Jason Rogers (gasdive on the org) can tell you what happens. The end result is EXACTLY the same as it would be for CO1 - and I don't hear anybody describing that as harmless or life giving.
On the other extreme, pure oxygen tends not to be a great idea most of the time either, as the folk at NASA had to be reminded on 1967/01/23.
So ANYTHING can be a poison or pollutant and right now - save for two or three whack job "scientists" who will always appear on a news show to provide a "balance" to the discussion and create the illusion of controversy with a fifty/fifty academic community split - there is no disagreement whatsoever amongst the straight pin crowd that the biggest threat to life as we have always known it on this planet is carbon dioxide - not Beavers or Polar Bears.
But nevertheless, they continue to grow by the billions. So I'm not real worried about Homo sapiens going extinct real soon. I'm not real worried about them going extinct at all actually. What I AM real worried about is them driving everything else into extinction before driving themselves into extinction.
Tad, I'll challenge you and everyone here to just take roughly the same amount of time that it takes to review and consider the issues and operational differences between curved and straight pin releases...
For me that would be about a tenth of a second - like looking at a square wheel or a flat tire in a parking lot. The bent pin has been around for two decades this year. Let's say you've got ten thousand AT pilots who've used them and are still doing so - despite the fact that they're welding themselves shut under fairly normal tow tensions and I've been trying to explain to everyone why since I started aerotowing regularly over a decade ago.
That makes me 63.1152 trillion times smarter than the superbrain of the hang glider AT community. And that's without factoring in the issue that nobody had to explain anything to me and I didn't need to see one weld itself shut. And that's also after swallowing a lot of concentrated fluoride after brushing my teeth like it tells you not to do on the PreviDent 5000 Plus tube. Do you have any idea how lonely, depressed, and hopeless that makes me feel?
Nah. I've always been pretty good at resisting conditioning and propaganda and desired effects. My family, church, and public school tried like hell to make a Christian out of me but I was a pretty solid atheist by age eight 'cause even then I needed two plus two to add up to four. A couple of years after that I figured out that the resources of the planet weren't infinite. And maybe around fourteen or so I knew that there had to be some really scary downside to our rapid consumption of hundreds of millions of years worth of fossil carbon deposits.
This fits into the two plus two equals four equation for me just fine, thank you.
Don't really need them. The satellite photos are pretty dramatic.
I'm not really expending all this energy for the purpose of saving each year one or two a**holes like the ones that typify the participants in this sport from themselves. This is just a little fragment of civilization in which I think I've got a small shot at winning one over religion for science. And the more science wins over religion the better the chances are for the hummingbirds, treefrogs, pitcher plants, and corals.
I've pissed away a lot of money, time and effort over the years on tools that would help others get airtime.. towrigs, tugs and thieving flight park partners...
Does Jim Gaar figure into this story?
...but no good deed goes unpunished...
Tell me about it.
I'm a whistle blower. Whistle blowers don't get to live well. It's in the rulebook. So I'm willing to settle for making other people's lives as miserable as I possibly can. (Zack, tell Bob how totally miserable I made everybody down in Houston for a couple of months.)
Don't worry. I plan on being as fair as possible to people I don't like (which is damn near everyone).
One day a soldier who had transgressed in some fashion had been brought before Lee. As he entered the tent to hear the man's story, he attempted to put him at ease by saying, "Don't worry, you will get justice here." To which the soldier supposedly replied, "That's what I'm afraid of."
I see those as mutually exclusive objectives.
Jack Axaopoulus
New Bob Kuczewski, Scott C. Wise rule
2010/09/27
After months of being smeared and attacked by these two guys, after everyone else else let it go, they are still at it on the torrey hawks forum. Even the new hawks forum is a cesspool for revisionist character assassinations against some of the best volunteers in the hang gliding community.
Well ive had it. Ive been pushed too far and am now defending myself and fighting back. They expect me to take punch after punch without countering. No more. Enough is enough.
TO PREVENT this ugly nonsense from ruining the new peace and tranquility that has occurred on the org since then, no BobK/Scott drama will be allowed to spill over onto this forum. All such threads will simply be DELETED.
This site is off limits to their vile from now on. I will not allow their destructive vitriol to take down this forum as it has the new hawks forum. Their new forum is just a pile of disgusting lies and smears. They no longer need the old torrey forum so I have shut it down and posted a counter message in self defense. They will play the victim now and email everyone in the world. Cry me a river. When you keep punching someone in the face for months, dont cry when they finally hit you back.
I know for a fact Bob and Scott will NEVER let it go and will continue to attack me, John Wright, John Borton, and other HGAA members that voted them out. But I will not allow that to ruin this site as well.
If anyone has an issue with this, just walk out the door. Dont threaten it, dont announce it, just walk out. Any such political nonsense will be deleted. Just leave instead. The Bob/Scott drama stops at the door. They will not be invited back and are not authorized to access this server in any way.
Ive really enjoyed the new peace at the org. Its been a lot quieter and more fun here. Lets keep it that way.
PM me if you really want to make a statement.
(EDIT: all the PM's so far have been very supportive and positive, thanks guys! )
THE END
hanggliding.org
band of brothers
"To be what you've never been you must do what you've never done." - Unknown
Rate this post
2010/09/27
I worry every time I see my PM notification, and then after I read it, just more and MORE support from everyone thanking me for getting rid of these people.
This community rules and is 100X better without them. THANK YOU ALL for your support. I really appreciate the flood of positive PM's. I expected only the people with an issue to PM and flame me. What a surprise when 100% of the PM's were positive instead
Another morning... another basket of support PM's
Thank you, thank you thank all!
Media BLOCKED
Damn near EVERYONE wants to come to the Davis and Jack Shows and be part of those vibrant communities. They're run for and by Machiavellian inbred semiliterate bent pin SH*THEADS and all the Kool-Aid drinkers are treated with tremendous respect and courtesy that they don't deserve.
US Hawks is ninety percent spammers and has about a dozen members that have posted more than twice about anything of any substance.
Kite Strings has FIVE members who fit that description. Kite Strings is designed to really really NOT wanna make 99 percent of people in hang gliding come and be part of the community. And as a consequence we've got a tiny but potentially very powerful educational tool and resource that I'm pretty happy with at the moment.
I just had the shitt kicked out of one of my fundamental assumptions about the dynamics of towing. The good news is that the error doesn't have any practical bearing on equipment, procedures, or safety but it's still embarrassing as hell.
But the Kite Strings community is based upon respect for science and data - not freedom of speech and respect for individuals just 'cause they've figured out how to breathe. We achieve cohesiveness and respect by all getting together on the same page with reality.
Couldn't agree more.
Merriam-Webster's defines a foible as "minor flaw or shortcoming in character or behavior". In hang gliding people with foibles have killed themselves and, way more importantly, other people just as dead as drug cartel hit men with assault rifles. We need to treat hang gliding people with foibles and opinions who don't / won't / can't fix them about the same as the other murderers for the collective good of the sport and its participants. Otherwise we have no future that I want any part of.
I made a post - 2011/02/25 15:57:22 UTC - on this thread in which I did my best to address a whole bunch of issues you raised on your previous. A LOT of work went into it. I'm guessing you got distracted and bogged down for a while by something else but I never got anything in a way of a response to the points I made.
In science and aviation there tend to be right or, at least, best answers. And we need to discuss some of these issues to the point of resolution to get some competent leadership and standards in place so we can brutally suppress deltaman's innovative and creative approaches to aerotowing equipment before he puts himself and/or my nephew up on anything remotely resembling it.
Maybe if we have some extra time left over we can discuss having Red stood up against a wall for advising people not to load test their flying wires before taking to the air.
I'm up the road from Annapolis a bit. I can be more specific as the need arises but for the time being I don't want people to be able to target their cruise missiles much more accurately than that.
Warren again,
The future of hang gliding is nothing without instructors...
The problem with that line of thinking is that instructors have been hardwired wrong by other instructors who have been hardwired wrong. Et cetera back into the Seventies.
Zack C - 2010/12/13
I had a very different mindset too back then and trusted the people that made my equipment. Since then I've realized (largely due to this discussion) that while I can certainly consider the advice of others, I can't trust anyone in this sport but myself (and maybe the people at Wills Wing).
This is where we are now as we enter our fifth decade. And it's not getting better - it's getting worse.
Dennis,
Whoa! You LIKE fifty page frothing at the mouth rants on issues that don't really concern your flavors of flying? Cool!
Plenty more where that came from. And be sure to check us out at:
http://kitestrings.prophpbb.com/
Don't be so sure. Wallaby, Quest, Florida Ridge, Lookout, Currituck, Blue Sky, Ridgely, Whitewater, Cloud 9, and Cowboy Up collectively don't know squat about aerotow. If you understand grade school science you're way ahead of them. Feel free to butt in any time - you'd be hard pressed to do worse.
Postby Bob Kuczewski » Tue Mar 08, 2011 7:33 pm
TadEareckson wrote:Sorry for the delay folks, lotsa stuff (relatively speaking) has been happening at Kite Strings lately and I've been pretty tied up over there.
No need to apologize. It's been hard for me to keep up with you here ... as it is!!! ;)
And I don't mind adding another plug for kitestrings...
I'd like to see more cross-referencing in our sport. Jack (hanggliding.org) has basically forbidden anyone from linking to this site. What's he afraid of?
TadEareckson wrote:Bob,
Sorry, we don't use that rulebook here. This is the US Hawks forum, and we're trying out a new set of rules. We're looking for people who want to live by a better set of rules.
Justice for all. I like it ... I think.
They're only mutually exclusive under an assumption of ignorance by that community. No one wants to get injured or killed in a towing accident. If they knew that THIS community was promoting standards that would help save them from injury or death, then they would surely be glad to come and be a part of THIS community. So they're not mutually exclusive. But it will take effort to show that THIS community is the better choice in the long run.
TadEareckson wrote:
Jack Axaopoulus
2010/09/27
I guess Scott and I should consider it an honor to have special rules made up just for us. :srofl:
TadEareckson wrote:US Hawks is ninety percent spammers and has about a dozen members that have posted more than twice about anything of any substance.
The web was designed to allow people to follow whatever interests them at the click of a button. Those of us who support that choice are proud to cross-link to other sites like Kite Strings, or hanggliding.org, or the Oz Forum, or USHPA. Those who fear such cross-linking are showing their fear of competition. Jack is all about promoting his site. He doesn't want anyone on hanggliding.org linking to USHawks. That's telling us something about his site ... and about him. He's all about having the biggest site. That's how he defines "winning". For the record, I'm happy to see Kite Strings have FIVE members or FIVE THOUSAND members.
This is going to sound cold, but I believe people have a right to make their own choices. I don't want a "nanny state" where anyone is telling me what I can and can't do ... for my own good. The sport of hang gliding would surely not exist if that thinking were carried to its logical extreme. There's something bred into all living things that urges them toward taking some degree of risk in their lives. Those who want to forbid that risk are essentially snuffing out the human spirit itself. I can't support that. I do support information. I support good information. I support exposing bad information. But I don't support dictating what anyone can or can't do. The fundamental principle of economics (and evolution) is two words: "people choose".
TadEareckson wrote:I made a post - 2011/02/25 15:57:22 UTC - on this thread in which I did my best to address a whole bunch of issues you raised on your previous. A LOT of work went into it. I'm guessing you got distracted and bogged down for a while by something else but I never got anything in a way of a response to the points I made.
I write a lot, and you write even more. How can I complain? :)
But it's difficult for me to keep up with everything you write. Some of it is lack of time, and some of it is lack of experience in the subject matter. I try not to offer opinions without the facts to back them up. So if I don't have the fundamental knowledge and I don't have the time to delve into the research, then I'll generally remain silent.
TadEareckson wrote:In science and aviation there tend to be right or, at least, best answers. And we need to discuss some of these issues to the point of resolution to get some competent leadership and standards in place so we can brutally suppress deltaman's innovative and creative approaches to aerotowing equipment before he puts himself and/or my nephew up on anything remotely resembling it.
I agree with most of that, but I'm not really able to contribute without more background in aerotowing. I'm sure some of it is obvious, but there may also be things that are counter-intuitive to the novice. Having never towed, that makes me a novice (or worse!!).
TadEareckson wrote:Maybe if we have some extra time left over we can discuss having Red stood up against a wall for advising people not to load test their flying wires before taking to the air.
I've heard both sides of that debate, and I'm not sure which side wins. I'd like to see Red come and discuss it. Unfortunately, he hasn't been here in a while. And that's what worries me even more. If we don't have good healthy debates, then it's difficult to decide the better course. That's what's so sad about Jack and Davis banning people. They've killed the debates that might save lives.
:srofl: I know what you mean. I've got a few of the Torrey PG folks mad enough to target me as well.
I grew up not far from Annapolis. I had a "Tom Sawyer" childhood fishing, crabbing, and generally hanging out near the tributaries of the Chesapeake Bay. I'll be sure to contact you if I go back for a visit.
TadEareckson wrote:Warren again,
Tad, I'm going to try to help you out here. There's no problem with Warren's statement or his line of thinking. He's absolutely right just as he stated it. But you're also right. We do need good instructors. But Warren's statement didn't preclude that. So I think you're reading something into Warren's statement that he didn't say. Fair enough?
TadEareckson wrote:Dennis,
Another plug for kitestrings, and I think that's great. You're more than welcome to put it in your signature line so that people who like what you write here can find more of it. Again, that's what the web is all about. :thumbup:
By the way, despite Dennis' current avatar, he's also a hang glider pilot (H2, I believe). Here's my favorite collection of his hang gliding photos:
Thanks for chiming in Dennis. I always enjoy it.
Postby Free » Tue Mar 08, 2011 10:26 pm
Well sorry, there is disagreement because I'm a straight pin kinda guy that doesn't believe CO2 is anywhere near the biggest threat to life as we have always known it. I wonder, is this the first time you have been proven wrong?
So you quit the Christian religion and joined the Malthusian religion of anthropogenic global warming instead?
Yes. You must be psychic!
What gave it away? :srofl:
This link will take a bit longer than checking a flat tire on a square wheel but there is tons of information here that deserves a look see before the decision is made to dictate death to millions so Al Gore can make billion$.
If you don't care to check it out maybe you will at least fill me in, if we were to agree that CO2 forces temperatures, how is CO2 credit trading going to fix it?
http://whatreallyhappened.com/WRHARTICLES/climategate.php
Warren.. a straight pin kinda guy
Free
Users browsing this forum: Chris McKeon and 51 guests
