Bill Cummings wrote:Good point Jim.
As Sandy puts on more weight keep an eye on the keel at the front pulley.
good point yourself Bill.
I think I will rummage around my aluminum bin and go ahead and sleeve it.
The danger of the forward keel breaking is probably a zip line created problem and not a real life problem?
If the keel breaks in real life I am guessing it will most likely be the portion rear of the kingpost.
One other thing that might fail at some point and need beefed up is the landing wire running front to rear along with the lower rear flying wires. That upper front to rear landing wire is probably a source of stretch as well. Wires do stretch....not much of course, but a long wire like the upper landing wire? yeah, there is probably some stretching going on.
I would like to pinpoint WHERE the stretching is coming from.
This last test shows a pilot traveling WAY forward of the fully stuffed position. We need to find out what part of this set up is allowing all that forward travel, then we can begin to control it.
The existing 1/4 inch aircraft bolt at the rear flying wire/rear landing wire junction will most likely survive just fine but we are going to find out.
WOW! we have some really spectacular crashes to look forward to as Sandy puts on a bit of lard.
I am very happy with both the speed and results of the last test.
I am going to continue testing with only 60 pounds but set up the camera from other points of view.
I really want to get a clear video of those rear wires squeezing together to break Sandys forward speed.
I am going to repeat testing with 60 pounds until consistent test results are confirmed but I am not popping the cork until we are bringing a 220 pound Sandman to a gradual stop without damage...
Thanks for all the good input!.....RS
