By the way, here's what I found at
http://www.firstflightinsurance.com/Sit ... ATIONS.asp:
- Insurance_Application_2014_12_07.png (122.35 KiB) Viewed 5224 times
That document doesn't define "participant", but I suspect it would include anyone kiting a paraglider. The fact that helmets are listed as the first item supports Wingspan's comments that insurance was a major motivating factor behind this change. Wingspan also correctly understood that Gabe Jebb may have been jeopardizing more than his own site with his conduct. Good job on the research Wingspan!!
Also, the SOPs for any organization must reflect and incorporate the organization's other obligations. The page I published above was from First Flight's web site, so I am not certain if that helmet requirement is in force with USHPA's current policy. But if it is, then USHPA's SOPs should either quote those exact same requirements or prominently refer to the insurance policy as part of the SOPs that pilots are expected to follow. It's probably a failure of long-time USHPA Insurance Committee Chairman Mark Forbes that this wasn't done until now. He should have known about this requirement (if it exists in USHPA's policy), and he would be the person responsible for disseminating it to pilots and instructors via the SOPs, rating tests, and general notifications.
While I would still prefer the regulation that I drafted above, if this were non-negotiable with the insurance carrier, then the insurance carrier's requirements would need to be honored.
Regarding the topic of this thread, it's quite likely that Gabe Jebb (given his life-long involvement with both USHPA and Torrey insurance requirements) knew about this particular requirement, but chose to ignore it. That explains his aggressive effort (assault and battery) directed at keeping me from documenting his conduct. The restraining order is the concession's concerted effort to keep me from documenting similar violations in the future.
