And I finally get caught up enough to respond to THIS thread.
I've developed and refined a lot of tow equipment technology that USHGA and the Flight Park Mafia has been happily ignoring and suppressing for about sixteen years. It was a lot of freaking painstaking work and I was afraid that if I were hit by a truck it would all be lost.
So I first created a text document - Mousetraps - describing the components in agonizingly precise detail so that anyone who really wanted to could reproduce what I had done - given a sufficient supply of aspirin.
Didn't get a digital camera before five years ago but then went to work illustrating the components to somewhat reduce the hellishness for someone undertaking the project.
The photography is excellent, professional even...
Thanks for noticing. After some clumsy starts I, if I do say so myself, got pretty good at setting up the shots and Photoshopping the crap out of them - literally down to the last pixel. A lot of them represent a long day's worth of setup and editing, some several.
I have no fond memories of any of that and I came to dread having better ideas which called for reshoots. (I'm feeling a bit queasy at the moment 'cause on Monday Joe Street of Ontario wired me about a very simple cable lanyard two point AT release he developed which makes everything else in the category look like the junk it is and at some point I'm gonna hafta stretch it out on the frame and set up the tripod.) But I figured that if I did the best photos humanly possible people might start suspecting that the work on the equipment might well be comparable. Of course that was before I got to better know the kind of a**holes that Jack and Davis cultivate on their fora.
From an engineering perspective that looks like a pretty clean way to separate the two ropes under a lot of tension with fairly little force. Since the distance between the ropes is very very small, they don't generate much torque to bind the pin in the barrel ... even with considerable tension.
Yeah. That's EXACTLY the kind of "Aha" moment I've been trying to trigger with all the Bailey Releasers. But instead I get comments like:
I can see how that "release" would not release at all, especially with 400lb of load.
Would/could not release at all. No better than any others.
When you pull your release and nothing happens , and you s*** your pants, then you will know how!
Doesn't matter that it blows seven hundred pounds of towline tension with a seventeen pound pull. Doesn't matter that it's gone up for tens of thousands of tandem tows with never the slightest problem. On the Oz Report you have unrestricted freedom of speech - as long as you line up with Davis. But I digress.
If you properly explore that site:
http://www.flickr.com/photos/aerotowrelease/and the sets:
Aerotow Release System
Cache
temp
particularly the first one - it shouldn't be too much of a challenge to figure things out. You gotta click on things, blow up pictures, and read descriptions. Start with the overviews and understand how the detailed stuff fits into the big pictures. This ain't rocket science - it's barrel releases and a four-string letting go of bridle ends.
If you can follow the schematics for a VG system in a Wills Wing manual this should be a walk in the park. The primary / frame mounted release system IS pretty much a VG system.
A lot of people reject what they don't understand.
It's not really intended for a lot of people. It's intended for people like Paul Farina, Steve Kinsley, Craig Stanley, and Joe Street who want to develop sane equipment. (Don't wanna jinx anything but I think I'm on the verge of getting Zack to pick up a drill.) I thought I'd be looking at maybe one in a hundred - but I think it's more like one in a thousand.
Seriously, I think a lot of people can't really tell what is going on with all the release photos. Hence the resistance.
The resistance occurs 'cause the hang gliding public believes that if there were better ways of doing things the a**holes who've been running the flight parks for the past twenty years would already be doing them that way. They think that driving a Dragonfly up and down a hundred times a day makes someone a qualified engineer. They need to get to know Bo Hagewood a lot better and see the tragic effects of that much exposure to carbon monoxide.
So what do you think about the idea of an animation to make releases clearer?
I greatly appreciate the offer but here's the problem...
Students take lessons at flight parks and think their instructors are gods.
They're trained on and sold s*** by these bastards and - 'cause a Stockholm Syndrome thing kicks in - even if something smells like s***, if they're told it smells like roses they're gonna smell roses.
Thus the market is continually flooded with s***.
It generally takes about three things lining up wrong at the same time to kill a pilot.
One of those things is ALWAYS gonna be pilot error. You can get away with flying s*** equipment almost all the time if you adjust your dolly for proper pitch attitude, secure the VG cord, don't take off in too much of a crosswind, check the streamers along the runway before you give a thumb's up, keep your speed up after you lift off, maintain good position, and don't get into an oscillation cycle.
So when you set the dolly a notch nose high, get rolled by a thermal generated crosswind gust as you're lifting off, and have no means of aborting the tow with your Wallaby or Bailey release 'cause you need BOTH hands to fight the roll, Tracy or Mitch is gonna be able to say...
This is a terrible tragedy. John was such a genuinely wonderful person and all of us here at Cloud Quest are DEVASTATED. We all need to take away a lesson from this as I know John would have wanted us to. It's VITAL that you set that nose angle properly EVERY time. Get one of the crew to check if you're not sure. And ALWAYS check those ribbons before giving the go-ahead.
And then they can happily ignore the issue that the third factor which was necessary to turn a bent downtube event into a broken neck was added to the equation at the cash register ten months before the impact.
We could show how they work ... and how they fail - including the failure modes of the soldered nail rig.
We've known exactly how they fail for twenty years but it doesn't matter 'cause nobody ever goes to prison for negligent homicide and thus the people in position to make positive change on a significant scale have absolutely no incentive to do so.
How many spinnaker shackles were grounded after Robin was killed?
