Re: Quadruplane hang gliders
Postby JoeF » Tue Jul 10, 2012 7:08 pm
Stagger. By far the most common stagger for quadruplane (quadraplane, quadriplane, quadroplane) hang gliders is with the top wing forward. I do not have any example of a hang glider with reverse stagger where the upper wing is projectionally most rear. Other terms: Positive stagger (top wing forward) and negative stagger (top wing is rearward projectionally). When no stagger exists, then "zero stagger" or "no stagger" would seem to be the terms; maybe "neutral stagger."
Discussion open for comparing conventional stagger (forward for top wing) and the reverse-stagger option. :?: :?: :?:
There are probably good reasons for stagger to be most commonly with the forward top configuration. Some biplane powered machines are with negative stagger.
Postby JoeF » Mon Jul 16, 2012 12:40 pm
Not sure if Miller's model was positive or negative stagger. Anyone?
Source: Neil Larson's study clips from Ground Skimmer.
Users browsing this forum: No registered users and 8 guests
