Brandon Russell - 2011/10/16
Ringgold, Georgia
I came really close to blowing my launch at Lookout Saturday. So close in fact, that I drug my right wing tip on the ramp.
After I landed I really started thinking about what I did wrong and I honestly wasn't sure. After looking at the video I have some thoughts but I would really like to hear some constructive criticism from you that realize that in high winds, the ramp at Lookout is a windy cliff launch, not a slope launch.
Paul Hurless
Reno
Having your hang strap taut will help you avoid that kind of problem. When it's loose you don't have that direct connection to the glider, which limits the control you'll have over it.
Brandon
Good observation, Paul.
Come to think of it, I usually make a conscious effort to pick the glider up high enough to tighten my hang strap. I didn't do that here.
Steve Corbin
Crestline
Get as far forward on the ramp as possible, this will help ensure that both wings are in "clean" air. It will also reduce the chances of a ramp strike if one wing does go down.
gluesniffer
I like to start with my straps tight too if the air is strong enough and smooth enough that the glider will rise off my shoulders.
Brandon
This is the main thing I was hoping someone would point out. In my preflight with the wire crew I even said "I will go all the way to the red line" ... the problem is that I didn't. If I would have, I believe things would have been very different.
I have a very good understanding of the dynamics to launch from this ramp, which is why I'm kicking myself for not moving far enough out into the "real" airflow. I knew that's what I was supposed to do. I had even told two or three pilots before me, "keep your nose down, and get all the way to the red line" ... why I didn't do the same ... there lies the problem. I don't know.
Robert
Australia
I have absolutely no experience with ramp launches but have done hundreds of high wind launches at Stanwell. I have a question...
In high winds is it possible to do a base bar launch on that or any ramp? That way you are flying the wing with a tight hang strap before you launch.
I basically only do base bar launches. If the wind is strong enough, anything over 10-12 knots, enough to float my wing, I use the base bar. To me I love the solid feeling of launching with my feet still on the ground but flying my wing with virtually full control through a tight hangstrap.
Nicos
Canberra
Maybe a tight hang strap would have alerted you to the dropping wing a nanosecond earlier...
Jonathan Dietch
I also agree that getting a little farther out into the airflow would have helped avoid the incident.
Just launch as far out into the airflow as you can safely get in high winds.
Ryan Voight
Yes, I agree walking up to (or past) the red line would be a good idea. If it's strong and you only need a few steps, not just moving to the start of the slope of the ramp, but actually starting ON the slope can further help.
Christopher
Steps 2 and 3 show a low glider with a slack hang strap being driven by your upper arms (good) and hands (not so good). Step 4 finds the glider supported purely by your hands; because your posture is nearly prone, you have no ability to support the dropping right wing.
I see the pilot lowering himself until the strap is tight.
Kinsley Sykes - 2011/10/17
I launched around 3:00. It was a strong day and very gusty with strong thermals rolling through. Most of what I see can be attributed to not being out to the red line. Both wings should be in the airflow. It gets turbulent further back and you can get knocked around, but it feels like you are in the airflow when you are not.
I like having someone on the rear wires as I am walking out due to ramp suck before you get fully in the airflow.
Windlord
Montana
Just launching with a loose hang strap started the reaction. Without weight being transferred to the CG point, the wing will want to follow the path of least resistance, no matter how hard you apply force to the DT's. It's no biggie, just correct the error next time.
The practice we got into launching high wind Torrey was the nose wire person would donut up on the wires and state "Pilot has the wing." This would give the pilot a chance to "feel" the wing.
fly,surf,&ski
Torrey Pines
Lots of good stuff has already been said, especially about getting all the way out as far as you can into the clean air...
Brandon
Thanks. The bad thing is that I knew to get farther out into the cleaner air ... I just failed to do it. Maybe this will help the next person remember just how important it is. I hope to never have to show you all another "lesson" again.
Nobody wrote:what ever you say Bob !
Users browsing this forum: No registered users and 39 guests
