Join a National Hang Gliding Organization:US Hawks at ushawks.org View my rating at:US Hang Gliding Rating System Every human at every point in history has an opportunity to choose courage over cowardice. Look around and you will find that opportunity in your own time.
In this video Ben begins to look at how to build logic that will translate a binary value into the inputs needed to drive a common seven segment LED display. In this video, the translation is all done with AND gates and OR gates. The resulting circuit is quite complex and requires 3 breadboards to drive a single 7 segment display. Later videos will replace all of that translation logic with programmable memory that simply remembers which segments should be turned on for which binary inputs (brute force).
In this video, Ben begins exploring the use of EEPROMs (Electrically Erasable Programmable Read Only Memories) as a more compact method for driving the seven segment displays used in his computer.
