MMOexp ARC Raiders: Finding the Hidden Seed Vault Key
This subforum provides a place where new users can post immediately while protecting the rest of the forum from automated posting (spam). Posts here will eventually be moved to a proper location in the forum.
If you have just registered (but are not yet approved) and would like to post to some other location in the forum, then please post here using the following rules:
  1. Enter a title for your post that would be appropriate for your intended destination.
  2. Use the first line of your post to specify the subforum and topic where you want your post to go. Prefix this with the phrase "New Topic" if you want to start a new topic in that subforum.
  3. Enter the rest of your post as you would like it to appear.
The moderator will review posts to this forum and move them to the desired location when approved. The first line indicating the desired location will be removed so your post ends up looking like a normal post. You will normally be added as an approved user at that time (if not sooner).
Postby Stellaol » Mon May 04, 2026 8:37 pm
Once you load into Stella Montis, your first goal is to reach the Seed Vault area. If you spawn near the Eastern Tunnel, you're already in a good position. From there, head toward the zipline that leads upward into ARC Raiders BluePrints the Seed Vault entrance.
After taking the zipline, move forward through the corridor and take the door on your left. This will bring you into a small research room that acts as your first interaction point for the quest.
Inside this room, you'll notice a set of computer terminals on the right-hand side. These are your first objective triggers. Interact with them to access the researchers' logs. This step is essential, as it advances the quest and unlocks your next objective inside the same area.
Once you've accessed the workstation and reviewed the logs, the game will prompt you to backtrack slightly into the previous room. Don't leave the area yet-you still have an important item to collect.
Look beside the large central computer structure. There should be a rack filled with hanging research suits. Search this rack carefully, as this is where the hidden Seed Vault Box Key is located. Interact with it to collect the key.
This item is mandatory for progression, so make sure it's added to your inventory before continuing. Without it, you won't be able to access the locked seed storage later in the quest.
Powering the Seed Vault Entrance
Now that you have the key, your next objective is to gain full access to the Seed Vault interior. The entrance is sealed behind large shutter doors that require a Power Cell to activate.
Fortunately, the Power Cell is usually nearby. In most runs, it can be found within or around the same computer room where you picked up the key. If it's not immediately visible, check the floor and adjacent corners of the room before moving on.
Once you locate it, pick up the Power Cell and carry it toward the main Seed Vault door. Approach the control panel and install the cell to restore power. This will activate the shutter mechanism and open the entrance.
Be prepared here-once the door opens, you may encounter a few hostile "Ticks" inside. These small enemies can quickly overwhelm you if ignored, so clear them out before proceeding deeper into the facility.
Unlocking the Seed Deposit Box
With the Seed Vault now accessible, move carefully toward the back section of the facility. Your next objective is the Seed Deposit Station.
This is a specialized interaction point where you can use the Seed Vault Box Key you collected earlier. Approach the station and interact with it to unlock the seed storage container.
Once unlocked, search the Seed Deposit Box thoroughly. After completing the interaction, the quest item-the Official Shutdown Documentation-will drop to the ground nearby.
Pick it up immediately. It's highly recommended to place it in a safe pocket or secure inventory slot to avoid losing it if you get into combat or need to extract quickly.
Extracting and Returning to Speranza
With the Official Shutdown Documentation secured, your final step is to extract safely from the area. Make your way back through the Seed Vault and head toward the nearest exit route.
The most convenient extraction point is the Seed Vault Airshaft, which is located just down the hall from the main facility. Once you reach it, use it to cheap ARC Raiders BluePrints return to Speranza.
Stellaol
Return to New Users Forum
Users browsing this forum: No registered users and 253 guests
