Re: Rigs for triangle control frame and harness practice
Postby brianscharp » Wed Jul 22, 2015 2:32 pm
Sounds like good times ahead. What glider are you going to use?
brianscharp
Postby Frank Colver » Wed Jul 22, 2015 3:25 pm
brianscharp wrote:Sounds like good times ahead. What glider are you going to use?
I've got an Alpha 210 on its way. Check out the video posted on the FDGS site of Hobson / Miller Day when Mike Meier brought one out to Dockweiler for demo flights. However, I didn't fly it that day. It was late in the day and I was already beat from running around in the sand since 9:30 am. With my weight (230) I wanted more wind for those legs. 8-)
BTW - I discovered that Vimeo had at some point changed my default to "only me". From now on I'll make sure that any Vimeo I download is the correct privacy setting.
Postby JoeF » Sun Jul 26, 2015 5:29 pm
Thanks, Frank, for showing shop steps in your harness adventure. Using shop-hang and ladder control frame are imprinting your shop with new flight resonances.
No rush! We will see your good works on next Funday Sunday.
Notice next post on ARP's grandson and friend in a practice rig that Tony set up.
Postby JoeF » Sun Jul 26, 2015 5:33 pm
ARP (yes, our early pioneer --- 1960) has recently set up for his grandson and grandson's friend a rig for practicing using harness and virtual triangle control frame (TCF).
Five videos have been uploaded and here linked:
http://youtu.be/W2lJ2Uq1FHI
http://youtu.be/LxPIw1i0SQo
http://youtu.be/rAGelsdDF-Y
http://youtu.be/LyYk5y9P3J4
http://youtu.be/H6Ul7iUGE7s
Hi Joe,
As with most children's activities , swings, roundabouts,, slides, climbing frames, etcetera, a helmet might provide some protection but in general they are not worn. Having spatial awareness and developing natural agility would likely be hindered by the wearing of protective gear such as helmets and pads. The consequences of hurting yourself are a good teacher and reliance on protective gear might dull this learning process. However I do normally wear protective gear when I consider it prudent.
I thought the prone take off swing goes hand in hand with the Little Hawk ground running exercise.
tag: ARPrig
Postby Frank Colver » Sun Jul 26, 2015 9:16 pm
I love it :!: :!: :!: Wish I had that when I was a kid. :thumbup: However, a friend did have a big eucalyptus tree on the edge of a steep drop. We would "Launch" the high swing from the roof of his chicken coup and swing out over the "abyss".
F Colver
Users browsing this forum: No registered users and 549 guests
