Postby JoeF » Fri Feb 14, 2025 9:44 am
Sorry about the fog during development:
This development note regards stacking segments that have no top or bottom material face.
Surprise me about nestable hexagonal cross-sectioned tube segments each of constant dimensions that stack upon placing capture plates between adjacent stacking segments.
ChatGPT said:
Imagine a set of nestable, hexagonal cross-sectioned tube segments, each featuring constant dimensions and designed to interlock seamlessly when stacked. These segments are perfect for modular, compact packing solutions. Their hexagonal shape allows them to be packed efficiently, with minimal wasted space between them.
The clever part is the capture plates — thin, lightweight but strong plates designed to be inserted between adjacent segments. These plates serve a dual purpose: they maintain the alignment of the segments, preventing them from shifting during storage or transport, and they help in compressing the stack into a compact bundle.
How it works:
Hexagonal Segments: Each tube segment has six flat sides, so when placed side-by-side, they fit together like puzzle pieces. Their uniform shape ensures they stack neatly, with no empty spaces between them (except for the necessary gaps for the capture plates).
Capture Plates: These plates are inserted between the adjacent segments. They are designed to fit snugly between the flat sides of the hexagonal tubes, aligning the segments perfectly and providing the force needed to keep them stacked. When stacked, the capture plates help create a uniform, solid bundle. The plate might have small hooks or features that lock into the adjacent tube segments to prevent any accidental slipping or misalignment.
Efficient Packing: Because of their hexagonal shape, the stack is incredibly stable and compact, with no wasted space that would normally occur in square or round designs. Unlike circular tubes, which require additional protective layers to prevent shifting, the hexagonal tubes nest together naturally, making this packing solution extremely efficient.
Expandable/Contractible: The beauty of this design lies in its flexibility — you can add more segments to the stack as needed, and each additional segment locks into place with the same ease, without disturbing the overall stack’s integrity. The capture plates adjust automatically with each new layer, keeping the structure intact.
Stability and Compression: The stack is self-compressing under load, as the hexagonal shape resists compression from all sides, ensuring that the stacked segments remain tight and aligned. The capture plates add an additional layer of pressure to maintain the shape, ensuring that no gaps or wobbling occurs.
This innovative system could be ideal for projects requiring modular parts that need to be easily transported, stored, or manipulated — from advanced structures like aerospace components to creative packing solutions for various outdoor gear.
You said:
Let's smooth out some understanding. The series of shells that have hexagonal cross-section nest during transport separate from the capture plates. Each shell has no top or bottom (they are simply cylinders of hexagonal cross section; e.g. one segment might be with a diagonal diameter of 12 inches and wall thickness of 1/32 inch. The next segment to nest in transport then could be 11 in and 14/16 in in diagonal diameter. That would give a nest play wobble space.
ChatGPT said:
Got it! Let's refine the concept further with this understanding:
The Design
You're envisioning a series of hexagonal shell segments that nest inside each other during transport, with the capture plates being separate components designed to hold the shells in their nested positions. The shells themselves are essentially hollow tubes with no top or bottom — just cylindrical shells with a hexagonal cross-section. The difference in the diameter of the hexagonal cross-sections between consecutive shells allows for a snug yet slightly adjustable fit, creating a small "wobble space" for efficient packing.
Key Features:
Hexagonal Cross-Section: Each shell has a consistent hexagonal cross-section, making the shell shape easy to stack and nest due to the angular geometry. The hexagonal shape offers more packing efficiency than circular tubes, especially when it comes to minimizing wasted space.
Gradual Nesting with a "Wobble Space": The shells have slightly different diagonal diameters (as you mentioned, the first shell might have a diagonal of 12 inches, and the next one 11.875 inches). This difference in diameter creates a slight play or "wobble space" between adjacent shells, allowing them to nest together comfortably without being forced tightly. This design enables more forgiving stacking, which helps with disassembly and reassembly.
Shell Wall Thickness: With a thin wall thickness (like 1/32 inch), the shells are light yet strong enough to maintain structural integrity. The reduced thickness contributes to the overall compactness and efficiency of the packing system.
Capture Plates: The capture plates are separate components used to maintain the alignment of the nested shells during transport or storage. These plates fit between each shell to prevent lateral movement or instability. Each plate might act as a spacer, keeping the shells stacked in a controlled manner while allowing for the slight wobble between adjacent segments. The plates can also help compress the shells into a tight, stable bundle for storage.
Transporting & Nesting:
Efficient Nesting: During transport, the shells nest one inside the other with minimal gap between them, except for the slight wobble space allowed by the graduated diameters. The shells may not touch perfectly along the edges due to the wobble, but the design ensures that they remain stable when stacked, avoiding excessive movement.
Separation of Capture Plates: The capture plates are stored separately, not inside the nested shells, to maintain their protective role without adding unnecessary bulk or complexity. They would be added when it's time to secure the nested shells for transport or storage.
Benefits of This Design:
Compact Storage: The slight wobble allows for smooth, flexible nesting that doesn’t force the shells to be tightly pressed together. This creates a balance between efficiency and ease of assembly/disassembly.
Minimal Wear: Since there’s a controlled wobble space, the shells won’t experience constant rubbing against each other. This reduces friction and wear compared to designs that force parts to be tightly compressed.
Flexibility in Packing: The modular nature of this system, where the shells vary slightly in size, allows for a more flexible, adjustable packing method. The slight tolerance between segments makes it easier to fit the parts together without needing perfectly matching sizes.
Simplicity and Low Overhead: Without needing integrated locking mechanisms or other complex mechanisms to secure the shells, the design is streamlined and easy to implement, with minimal weight and manufacturing complexity.
Applications:
This nesting shell system could be used for:
Modular structural components: Think aerospace, automotive, or engineering projects where you need compact storage without sacrificing integrity.
Packing for transportation: Items like hang glider spars or other outdoor gear that need compactness while avoiding excessive wear during transport.
Expandable/Contractible Frameworks: The system could allow for expanding or contracting the length of a modular structure by adding or removing shells, with each shell adding or reducing the system's total length.
This system of stackable, interlocking hexagonal shell segments with wobble space between them, combined with separate capture plates, offers an elegant balance of space-saving, ease of transport, and modularity.
You said:
We need to correct our understanding of the capture plates. The capture plates do not help storage. The capture plates are used to place between the stacked cylinder segments thus giving "platform" separation between adjacent cylinder segments. The capture plates during transport are one upon the other, say 12 capture plates, each 1/32 inch thick. A final stack of cylinders with a stacking plate between successive adjacent cylinder segments would make a tall tower, from a distance appearing as a stepwise tapered pole. When adding tension cables that compress the tower one gets a beam or spar.
ChatGPT said:
Thank you for the clarification! Let’s walk through the updated design with the correct role of the capture plates in this system:
Revised Understanding:
Hexagonal Cylinder Segments: The primary components are hollow cylindrical segments with hexagonal cross-sections, and they are designed to nest into one another. These cylinders have a consistent shape and size, with adjacent cylinders having slightly different diagonal diameters (e.g., 12 inches and 11.875 inches in diagonal diameter) to create a small amount of wobble space during transport, allowing the cylinders to nest together compactly while maintaining a slight separation.
Capture Plates: The role of the capture plates is now more clear. These thin plates (say, each 1/32 inch thick) are not used for storage or packing the segments together but are inserted between each stacked cylinder segment to create a platform separation. Each capture plate acts as a thin spacer that provides structural support by separating adjacent segments when they are stacked in a tower-like formation. This separation prevents the segments from directly contacting each other and helps maintain the stability of the stack.
The capture plates are stacked separately from the cylinders during transport, forming a "stack" of plates, which could number around 12 or more, depending on the height and number of segments.
These plates are inserted one by one between the cylinder segments, with each plate serving as a step in the overall tower.
Stacking Tower Formation: When the cylinders are stacked with the capture plates inserted between them, they form a tapered tower-like structure. From a distance, the stack of hexagonal segments, along with the separator plates, may appear like a stepwise tapered pole due to the varying diameters of the stacked cylinders.
Compression with Tension Cables: Once the cylinder segments are stacked with their respective capture plates between them, tension cables are added to the structure. These tension cables serve to compress the entire stack into a stable, rigid beam or spar. The compression from the tension cables will lock the entire structure together, creating a beam with enhanced strength, while the separation provided by the capture plates helps maintain the intended geometry and prevents unwanted shifts.
Key Elements:
Modular, Nesting Segments: The hexagonal cross-sectioned cylinders are designed for efficient nesting, each having slightly different sizes to create a wobble space for easy stacking and compact transport.
Capture Plates as Structural Spacers: Each capture plate is placed between the stacked cylinder segments to maintain consistent spacing and alignment. They provide a uniform "platform" separation between the segments, ensuring the stability and controlled geometry of the stack.
Tension-Cable Compression: The addition of tension cables compresses the entire stacked assembly, converting it into a rigid beam or spar. The compression locks the tower together while maintaining the geometry defined by the capture plates.
Functionality:
Stepwise Tapered Tower: The stacked cylinders with capture plates inserted create a tower-like structure with a tapered appearance due to the slightly differing sizes of adjacent segments. The effect is like a series of "steps" going upwards, with the stack becoming progressively smaller as the segments nest within each other.
Compression and Beam Formation: The final step, involving tension cables, transforms the stacked tower into a beam. The tension cables compress the stack from top to bottom, increasing the stability of the assembly and converting the tower structure into a rigid spar. The capture plates maintain the precise platform separation that allows the compression to work effectively without destabilizing the geometry.
Benefits:
Modular and Adjustable: The system is highly flexible, allowing for easy addition or removal of segments and capture plates to adjust the height and length of the final beam or spar. This modularity could be useful for creating structures of varying sizes or for applications that require adjustments in length and strength.
Efficient Transport and Assembly: During transport, the shell segments nest efficiently, and the thin capture plates remain stacked separately. Upon arrival at the construction site, the segments can be easily assembled by inserting the capture plates between the cylinders, followed by tensioning the cables to form the final beam or spar.
Stability with Minimal Material: The use of thin capture plates (1/32 inch thick) allows for a structure that is lightweight but stable. The tensioning mechanism provides the required strength, while the separation created by the capture plates ensures the system remains functional and aligned under load.
Applications:
This system could be particularly well-suited for:
Modular framework structures: Useful in scenarios where a portable and adjustable beam or spar is required, such as temporary scaffolding, modular towers, or adjustable architectural features.
Portable transportation beams: As with your hang glider design, this approach could be adapted to create beams that are compact for transport and strong when assembled.
Portable structures in engineering and aerospace: The modularity and compression system could allow engineers to create temporary or scalable structures with ease.
In this corrected understanding, the role of the capture plates is crucial in providing controlled separation between the segments, ensuring stability, and making the assembly process efficient, while the compression with tension cables is what ultimately turns the tower into a robust beam or spar.
You said:
Most all you wrote is accurate, but the following phrase shows a slight misunderstanding: "with the stack becoming progressively smaller as the segments nest within each other." The stack becomes progressively smaller in diameter while the segment lengths are constant, if wanted; but during the stacking there is no nesting occurring. Nesting occurs only during tight packing for transport.
ChatGPT said:
Thank you for that clarification! I now understand that the nesting only happens during transport, where the segments are packed tightly inside each other for efficient storage and transport. The key point is that during the stacking process, the segments maintain their fixed lengths and do not nest within each other; rather, they are stacked with their diameters progressively reducing as you move up the tower. The capture plates are used to maintain separation between adjacent segments during stacking, which helps to preserve the structure and geometry of the stack.
Corrected Understanding:
Stacking Process: During the stacking of the cylinder segments, each segment maintains its full length. The segments are stacked one atop the other, with progressively smaller diameters, which creates the appearance of a stepwise tapered tower. There is no nesting between the segments at this point—each segment sits on top of the other, separated by a capture plate, which helps to maintain consistent spacing and alignment.
Nesting for Transport: The nesting of segments occurs only when they are being packed for transport. The shells fit inside each other with the slightly varying diameters, allowing them to nest and minimize the overall volume for transport. The segments do not nest during stacking but are instead kept separated by the capture plates to create the desired stepwise structure.
Revised Key Points:
Fixed Segment Lengths: During stacking, the segment lengths remain constant, and the only variable is the diameter of each segment. The segments are stacked with progressively smaller diameters to create the tapering tower.
Capture Plates as Separators: The capture plates are inserted between each pair of adjacent segments to maintain a fixed distance between them, ensuring that the segments are aligned properly and not shifting out of place.
Nesting Only for Transport: The nesting process, where the segments fit into each other for compact packing, happens during transport. This nesting makes the system more space-efficient during storage and movement.
Tapered Stack with Progressive Smaller Diameters: As the segments are stacked, the diameters progressively get smaller, creating a visually tapered tower. This tower is supported by the capture plates and compression from tension cables, forming a rigid beam or spar.
Summary:
The nesting of the segments is a feature for transport, while during the stacking process, the segments are arranged by size, with their lengths remaining constant and progressively smaller diameters, creating the tapered effect. The capture plates keep the segments separated while they are stacked, and once the tower is fully assembled, tension cables compress it to form a solid beam or spar.
Thank you for pointing that out! Does this now reflect your design concept more accurately?
You said:
Yes, thank you. However, it can be noted that a cylinder segment need not match in length the other segments; the matched lengths is just a standard starting point. Nothing bad happens if the lengths of segments change; indeed one could choose to have a gradual length change to shape the spar. And wall thicknesses of the segments could vary or stepwise taper from one to the next; however, attention would be needed to choose wall thickness and wobble gap so as to keep the nesting ability of the collection.
ChatGPT said:
You're absolutely right! The length of the cylinder segments does not necessarily have to be uniform across all segments, and having a gradual change in segment length can indeed be a useful feature for shaping the spar. This would allow for customization of the spar's geometry, creating specific tapering or bending profiles depending on the application.
Key Points on Segment Length and Wall Thickness Variation:
Length Variation:
While the standard starting point assumes uniform segment lengths, there's no inherent problem with length variation between segments. Varying the length of the cylinder segments can be used to shape the spar and achieve the desired structural properties.
A gradual length change could allow the spar to have a tapered shape along its length or introduce specific bending profiles to achieve optimal aerodynamic or mechanical properties. For example, the base of the spar could be made of longer segments, and the upper portions could feature shorter segments, creating a smoother transition in geometry.
The wall thicknesses of the segments could also vary or stepwise taper from one segment to the next. This would add to the overall customizability of the spar, allowing you to adjust the structural integrity, flexibility, and weight distribution of the beam.
When varying wall thickness, careful attention should be paid to the wobble gap between adjacent segments. As you mentioned, maintaining the ability to nest the segments together efficiently for transport remains crucial. So, adjusting the wall thickness while ensuring that there is enough room for nesting is key to maintaining the compactness during transport.
Nesting Considerations:
If you're varying both wall thickness and diameter, it’s important to carefully manage the wobble gap—the space between adjacent segments—so that the segments can still nest without creating excessive gaps that could interfere with the structural integrity during compression.
A stepwise taper in the wall thickness, similar to the gradual changes in diameter, would allow for a progressive structural design, enabling different regions of the spar to bear different loads based on their thickness or diameter.
Practical Implications:
Structural Performance: Varying the lengths and wall thicknesses of the segments allows for a tailored spar design with specific regions optimized for strength or flexibility. For instance, the base of the spar could have thicker walls to resist compression, while the upper part could have thinner walls to reduce weight.
Customization: The design becomes highly customizable, making it adaptable for different applications. Whether you're aiming for a straight, tapered, or bendable spar, this approach gives you the flexibility to achieve the desired mechanical properties and geometry.
Transportability: The main challenge remains ensuring that the segments can nest efficiently for transport, even with variations in lengths and wall thicknesses. However, the concept of having small tolerances between segments (through the wobble gap) remains the core principle for efficient packing and ease of transport.
Conclusion:
With the ability to adjust segment lengths and wall thicknesses, you can create a more tailored and flexible spar design. Just as you noted, the key is to carefully balance these variations with the wobble gap to ensure that the segments still nest efficiently during transport while allowing for the customized shaping of the spar as needed for specific performance requirements.
Thank you for the great insights! Does this updated explanation meet your expectations?
Prevent lateral sliding when spar is in compression:
Designing the **capture plates** to secure the rims of two neighboring cylinders in the stack, while considering **castellated edges** and **receptive holes** in the plates, can provide an efficient and stable connection between the segments. Let's break down how this design could work and the key considerations.
### Design Concept for Capture Plates:
1. **Castellated Edges on Cylinder Rims**:
- **Castellated edges** on the rims of the cylinders could consist of small, alternating projections and recesses along the rim of each cylinder, similar to a "gear" profile. These can interlock with corresponding features in the **capture plates**, creating a secure and precise connection.
- The projections (or "teeth") could extend a small distance from the edge of the cylinder rim, and the **recesses** would be sized to fit the teeth of adjacent segments snugly.
2. **Receptive Holes in the Capture Plates**:
- The **capture plates** would have corresponding **holes** or **slots** to accept the projections from the castellated edges. These holes need to be precisely sized to allow for a tight fit between the **projections** on the cylinder rims and the **capture plate’s holes**. The goal is to ensure that once the cylinders are stacked with the capture plates between them, the projections from one cylinder are inserted into the holes of the adjacent capture plate, securing the positions of the segments relative to each other.
- The **holes** in the capture plates could be designed to match the shape and spacing of the castellations, forming an effective locking mechanism. These holes could be circular or slightly elongated, depending on the specific castellated design.
3. **Interlocking Mechanism**:
- When you place the **capture plate** between two cylinders, the projections from one cylinder will **insert into** the receptive holes in the capture plate. This creates an **interlocking fit** that holds the two cylinders in place, preventing sliding or shifting of the stack.
- The **tight mutual insertion** will ensure that the cylinders stay aligned during stacking and compression. However, there should still be enough **gap or clearance** in the holes to allow for easy insertion but tight enough to prevent wobble.
4. **Material Considerations**:
- The **capture plates** should be made from a material that is **strong enough** to resist deformation under compression but **slightly flexible** to allow for easy insertion and removal. A thin metal or a **rigid plastic composite** could be suitable for this.
- The **castellated edges** of the cylinders would likely be **machined** or molded to precision to ensure accurate fitment with the capture plates.
### Example Design Workflow:
1. **Castellation Design on Cylinder Edges**:
- Decide on the number of teeth per rim based on the cylinder diameter and desired separation between cylinders. For example, you might have **4 or 6 teeth** along the edge of each segment. These teeth should be small enough not to interfere with nesting but large enough to interlock securely with the capture plates.
- The teeth could be spaced **equidistantly** around the rim, with each tooth having a **small tapered shape** (e.g., triangular or trapezoidal).
2. **Capture Plate Design**:
- The **capture plate** should be slightly **larger** in diameter than the cylinder to allow the projections to pass through the holes easily.
- The **holes** in the capture plate should match the **profile** of the castellation. If the teeth are triangular, the holes in the plate should have a similar shape or be slightly elongated to accommodate them.
- The **thickness of the capture plates** should be consistent, but enough space between the plates and the cylinder rims should exist to prevent the plates from getting crushed under compression.
3. **Stacking and Locking**:
- When stacking the cylinders, a **capture plate** is placed between each pair of adjacent segments. The teeth on the cylinder edges slide into the holes of the capture plate, creating a secure connection.
- **Tension cables** or other compression methods would then compress the tower, causing the segments to press together. The interlocking castellated edges help prevent any shifting or misalignment under load.
4. **Potential Adjustments**:
- If you want to fine-tune the stacking, the **depth of the castellated teeth** or the **diameter of the holes** can be adjusted to modify the **tightness** of the fit. This would affect how much **play** there is between adjacent segments during transport and stacking.
- If desired, you could introduce **coatings or lubrication** on the teeth or plate surfaces to facilitate smoother insertion and prevent wear.
### Visualizing the Design:
- **Cylinder Rim (Castellated)**: Small projections (teeth) along the rim of each segment.
- **Capture Plate**: A flat, rigid plate with **receptive holes** matching the castellated teeth profile.
- **Mutual Insertion**: As segments are stacked, the teeth on one segment insert into the corresponding holes of the adjacent capture plate, locking the two segments together.
### Benefits of This Design:
- **Secure Stacking**: The interlocking castellated design prevents sliding, wobbling, or misalignment during stacking and compression.
- **Efficient Transport**: The plates can be stacked one upon another, allowing for efficient transport of the stack, while maintaining stability.
- **Flexibility**: Minor adjustments to the size or number of teeth, as well as the number of holes in the capture plates, allow for customized fitment depending on the specific application.
### Conclusion:
This design approach—using **castellated edges** on the cylinder rims and **receptive holes** in the capture plates—offers a **stable, precise**, and **easily assembled** connection between neighboring segments in the stack. The interlocking mechanism will keep the stack secure and prevent unwanted shifting or wobble, while still maintaining flexibility in the design for customization.
Postby JoeF » Fri Feb 14, 2025 12:12 pm
A Novel Join-Tube Development: Full Spar Taper via Multiple Conical Segments with Nested Tote Packing—Seizure Prevention in Axially Compressed Spars Using Helical-Wrapped Sheathed Elastic Line
Tube A at the join is pressed for hoop tension; tube B at the join is compressed hoopwise; the interleaved sheathed elastic during use in the joint is compressed as the axial compression of the assembly occurs.
ChatGPT said:
Got it! Your design uses hoop tension in Tube A and hoop compression in Tube B, with the sheathed elastic interleaved in the joint. The axial compression during use further compresses the sheathed elastic, reinforcing the snug fit.
How This Works in Detail:
Assembly:
Before inserting Tube A over Tube B, the sheathed elastic is wrapped around Tube B in an interleaved pattern.
When Tube A is pressed onto Tube B, its hoop tension expands it slightly while Tube B compresses hoopwise.
The elastic sheath fills any microscopic gaps, ensuring a tight fit.
During Use (Axial Compression Applied):
The axial load pushes Tube A further onto Tube B, reinforcing the hoopwise tension-compression effect.
The sheathed elastic is compressed, creating extra friction and grip, stabilizing the joint further.
The system maintains the snug fit without requiring adhesives, bolts, or additional hardware.
Disassembly (Release Mechanism):
To separate the tubes, simply pull the pigtail of the sheathed elastic.
As the elastic stretches and exits the interleaved gaps, it thins out, reducing the internal pressure in the joint.
This gradually releases the hoop compression in Tube B, allowing Tube A to slide off with minimal force.
Advantages of This Approach:
✔ Secure Fit – The combination of hoop tension and axial compression ensures a firm, rattle-free connection.
✔ Tool-Free Disassembly – Just pull the pigtail, and the joint loosens gradually, making breakdown easy.
✔ Self-Adjusting Snugness – The system automatically compensates for minor variations in tube diameter.
✔ Lightweight & Simple – No locking pins, adhesives, or extra weight—ideal for your TPHG design goals.
✔ Wear Reduction – The elastic sheath absorbs friction, minimizing tube wear over repeated assemblies.
This is an elegant, self-releasing snugging system for your telescopic spar hang glider. Would you like to explore different sheath materials or elastic configurations for optimization?
Postby JoeF » Fri Feb 14, 2025 1:45 pm
CF tube-making development note:
By adding this layer of release tape over the sheathed elastic string, you're increasing the chances of a smooth, defect-free pullout, especially in situations where mandrel imperfections might be present. This extra layer provides redundant protection against unwanted bonding and creates an additional level of control over the release process.
Postby JoeF » Sat Feb 22, 2025 5:01 pm
Note in the inflatable arena:
Modular inflatables gathered for global spar?
Postby JoeF » Wed Feb 26, 2025 5:51 pm
The Handles Hang Glider ?
Collect handles tossed in trash bins. Use them as spar segments. Broom, mop, pool cleaners, window washing, boat grabs, etc. handles.
Aluminum, fiberglass, steel, veiled steel, carbon fiber, other plastics, hybrid materials, ...
Here are some types of handles that are often discarded and could be collected for spar segments:
Broom handles – Wooden, aluminum, or plastic handles from old brooms.
Mop handles – Similar to broom handles, often made of aluminum or fiberglass.
Shovel handles – Wooden or metal handles from broken shovels.
Rake handles – Long handles from garden rakes.
Hockey sticks – Lightweight composite or wooden shafts.
Ski poles – Aluminum or carbon fiber poles from old skis.
Tent poles – Collapsible aluminum or fiberglass tent poles.
Umbrella frames – Metal or fiberglass shafts from broken umbrellas.
Fishing rod blanks – Carbon fiber or fiberglass rods from broken fishing poles.
Golf shafts – Lightweight graphite or steel shafts from discarded clubs.
Telescopic poles – Such as window-washing poles or extendable painter’s poles.
Walking sticks / Trekking poles – Aluminum or carbon fiber poles used for hiking.
Old flagpoles – Small, portable flagpoles often made of aluminum or fiberglass.
Pool skimmer handles – Long aluminum handles used for pool maintenance.
Crutch shafts – Aluminum or composite shafts from medical crutches.
Curtain rods – Metal or fiberglass rods used for hanging curtains.
Antenna masts – Telescoping metal poles from old antennas.
Kayak paddles – Carbon fiber or aluminum shafts from broken paddles.
Snow shovel shafts – Lightweight aluminum or plastic shafts from broken snow shovels.
Wind turbine blade spars – Small broken spars from hobbyist wind turbines.
Windsurfing masts – Fiberglass or carbon fiber poles from old windsurfing rigs.
Pickaxe handles – Sturdy wood or composite handles from broken pickaxes.
Extendable boat hooks – Aluminum or fiberglass poles used in boating.
Archery stabilizers – Carbon fiber rods from broken bows.
Tarp poles – Collapsible poles used for tarp shelters.
Tripod legs – Aluminum or carbon fiber legs from discarded camera tripods.
Selfie sticks – Telescoping metal or plastic shafts from broken selfie sticks.
Boom microphone poles – Extendable poles used in film and audio recording.
Garden tool extensions – Long handles from broken hoes or edgers.
Hiking staff cores – Composite or wooden cores from damaged hiking staffs.
Ladder stabilizer bars – Lightweight aluminum bars from ladders.
Parasol shafts – Fiberglass or metal poles from broken sun umbrellas.
Light stand poles – Aluminum rods from discarded photography light stands.
Soccer goal frame segments – Metal or plastic poles from broken portable goals.
Fence post supports – Hollow metal or composite posts used for fencing.
Postby dhmartens » Thu Feb 27, 2025 9:30 pm
We are restricting our airframe during wartime but we can do something else with it and post those results.
the pric e is $85,000 but china will sell it for $6,000 to $20,000.
Tiny Packed HG Movement
Postby JoeF » Fri Feb 28, 2025 8:10 am
Hang glider airframes assembled from tiny packs follow several rising patterns.
Mastery over those blossomings from tiny pack to "clear"
may net sweet fruits of mind, body, and spirit during turmoil or peace.
Hang glider airframes, born from tiny packs, unfold in soaring patterns.
Mastery of their blossoming—from compact form to open flight—
may yield rich fruits of mind, body, and spirit, in both turmoil and peace.
Postby JoeF » Wed Mar 12, 2025 6:22 am
Appreciating Tool and TPHG (tiny-pack hang glider) Salvaging Tool
Substantial List of Products Using Carbon Fiber Tubes (≤2" OD)
  • Aerospace & Aviation
    • Drone Frames – Lightweight, strong tubes for quadcopters and fixed-wing drones.
    • Aircraft Control Rods – Used in push-pull control systems for experimental and ultralight aircraft.
    • Telescopic Wing Structures – Small UAV wings and foldable wing spars.
    • Satellite Components – Small tubular structures for lightweight space applications.
    • Hang Glider & Paraglider Components – Structural supports and control bar tubing.
  • Sports & Recreation
    • Bicycle Components – Seat posts, handlebars, and frame sections.
    • Fishing Rods – Carbon fiber blanks for strength and flexibility.
    • Archery Equipment – Bow stabilizers, arrow shafts, and risers.
    • Golf Club Shafts – Lightweight shafts for optimized performance.
    • Hiking & Trekking Poles – Ultra-light poles for outdoor adventures.
    • Ski & Snowboard Poles – Strong and lightweight alternatives to aluminum.
    • Kite Spars – Rigid supports for high-performance kites.
  • Robotics & Automation
    • Robotic Arms & Manipulators – Lightweight yet rigid robotic structures.
    • Automation Conveyor Rollers – Small-diameter lightweight rollers.
    • Gimbal Arms & Stabilizers – Used in camera stabilization systems.
  • Marine & Watercraft
    • Sailboat Spinnaker Poles – Lightweight alternatives to aluminum or fiberglass.
    • Outrigger & Fishing Rod Holders – Used on boats for trolling and fishing support.
    • Rowing & Kayak Paddle Shafts – High-performance paddles.
    • Mast & Boom Components – Small mast and boom sections for ultralight sailboats.
  • Automotive & Motorsports
    • Roll Cage Components – Used in lightweight race car frames and roll bars.
    • Prop Shafts & Drive Shafts – For high-performance vehicles.
    • Exhaust Tubing – Heat-resistant, lightweight alternatives to metal.
    • Suspension Components – Used in custom racing suspensions.
    • Motorcycle & Scooter Parts – Handlebars, exhaust supports, and frame components.
  • Telescoping & Extension Products
    • Camera Tripods & Booms – Lightweight, strong telescopic legs and booms.
    • Mic & Lighting Booms – For film and production applications.
    • Surveying & Measurement Poles – Used for land surveying.
    • Tent & Shelter Poles – High-strength supports for lightweight camping gear.
    • Selfie Sticks & Monopods – Telescoping camera accessories.
    • Pool Cleaning Poles – Extendable, lightweight poles.
  • Industrial & Engineering Applications
    • Composite Roller Tubes – Used in various industrial machinery applications.
    • Medical Equipment Structures – Used in prosthetics and exoskeletons.
    • Textile Industry Rollers – High-speed rollers for textile manufacturing.
    • Inspection & Maintenance Poles – Telescopic poles for infrastructure inspection.
    • Antenna Masts & Radio Equipment – High-strength supports for communication equipment.
  • Scientific & Research Applications
    • Telescope & Optical Equipment Supports – Used in lightweight optical mounts.
    • Lab Equipment Frames – Structural components for lab setups.
    • Scientific Instrument Housings – Used for supporting sensitive research equipment.
    • Wind Tunnel Testing Models – Structural elements for aerodynamic testing.
  • Defense & Tactical Applications
    • Weapon Suppressor Tubes – Lightweight, high-strength tubes for firearm accessories.
    • Carbon Fiber Baton & Nightstick – Lightweight law enforcement gear.
    • Tactical Staffs & Survival Tools – Strong, lightweight alternatives to metal staffs.
  • DIY, Custom Fabrication & Hobbyist Applications
    • RC Planes & Helicopters – Used for spars, fuselage, and rotor shafts.
    • 3D Printing Frame Supports – Used in high-performance printers and CNC machines.
    • Furniture & Home Decor – Used in modern chairs, tables, and artistic designs.
    • Musical Instruments – Carbon fiber tubes used in drumsticks and wind instruments.
    • DIY Carbon Fiber Structures – Custom projects where strength and weight savings are critical.
Tube shapes
Aero / Streamline
Hexagonal
Octagonal
Oval
Rectangular
Round
Square
Aspects:
OD
ID
Wall
Fiber quality (Standard Modulus, Intermediate Modulus, High Modulus)
Lay
Finish
Resin
Ratio of resin to fiber
Curing method
Strength
Layers
You're covering many critical aspects of carbon fiber tubes, but here are some additional factors that might be missing:
Additional Tube Shapes:
  • Triangular – Used in specialized structural applications.
  • Elliptical – Similar to oval but with different proportions for aerodynamic applications.
  • D-Shaped – Common in high-strength, unidirectional load-bearing structures.
  • Tapered – For applications requiring varying stiffness along the length of the tube.
Additional Aspects to Consider:
  • Weave Type – Plain weave, twill weave, unidirectional, or braided configurations affecting flexibility and strength.
  • Orientation of Fiber Layup – Specific angles (e.g., 0°/90°, 45°/45°, quasi-isotropic) that influence torsional vs. axial strength.
  • Compression Strength – Crucial for load-bearing applications, especially in aerospace and robotics.
  • Impact Resistance – Determines how well the tube withstands sudden shocks or forces.
  • Density and Weight per Foot – Helps with performance-to-weight optimization in various industries.
  • Heat Resistance – Some resins and curing methods improve thermal stability for high-temperature applications.
  • Electrical Conductivity – Some carbon fiber tubes are conductive, while others use resins that insulate.
  • Chemical Resistance – Important for harsh environments, such as marine and chemical industry use.
  • Coatings & UV Protection – Some tubes require protective coatings to prevent UV degradation.
  • Post-Processing Options – Whether the tube is available for drilling, bonding, or additional machining.
Postby JoeF » Fri Mar 14, 2025 8:53 pm
Disclaimer – Read Before Proceeding
The discussions, ideas, and experiments shared in this thread are purely for educational and exploratory purposes.
This is not an instructional guide or a recommendation to build, fly, or use any form of hang glider, kite, or aerial device.
Hang gliding and experimental aircraft design involve significant risks, including serious injury or death.
Any individuals who choose to experiment with concepts discussed here do so entirely at their own risk.
The contributors to this discussion make no guarantees regarding the safety, reliability, or performance of any ideas or designs shared.
No liability is assumed by the authors, contributors, or forum hosts for any harm, damage, or losses resulting
from the use or misinterpretation of the information presented. If you choose to pursue similar projects,
you alone are responsible for your actions. Always seek expert guidance, follow all applicable laws and regulations, and prioritize safety at all times.
By continuing to read or participate in this discussion, you acknowledge that you understand and accept these terms.
Postby Chris McKeon » Fri Mar 14, 2025 9:25 pm
I HAVE A NEED FOR something Like what You Guys are Making. Please call Me Chris 925-497-1059
Users browsing this forum: Google [Bot] and 683 guests
