Re: Ultra-Portable Hang Glider Design Movement
Postby Semper Fidelis » Tue Mar 25, 2025 2:12 pm
JoeF wrote:UPHG :: ultra portable hang glider
This definition sounds perfect to me !
:thumbup: :thumbup:
Semper Fidelis
Semper Fidelis
UPHG
Postby JoeF » Tue Mar 25, 2025 6:15 pm
Warning:
52 minutes:
UPHGs may well evolve from having digested insect blessings ...
Postby Chris McKeon » Tue Mar 25, 2025 6:28 pm
My Self: I like the Sound of "U-P-P": Ultra-Portable Predator.
Ultra-Portable Hang Glider Design Movement:: UPHG
Postby JoeF » Wed Mar 26, 2025 3:21 pm
Ultra-Portable Hang Glider (UPHG)
Design Movement
Stay-Line Anchoring Using Joe Loops
In previous discussions, a single Joe Loop was considered as an option for anchoring both the flying and landing crossline stays at a given spar-strut junction. However, this approach presented some challenges, including slipperiness and snubbing considerations. Additionally, an important factor was not previously addressed: the inability to tailor differential strengths for handling distinct flight and landing loads.
This technical note explores an alternative approach—using two Joe Loops at a single spar-strut join—to independently secure the flying stay and the landing stay, offering improved load distribution and control. Diagonal plane-framing lines at the same join are not discussed here, as they can be addressed separately.
Two Joe Loops at the Join
Instead of a single loop, two independent Joe Loops are employed, each cinching around the spar and passing through itself for a secure hold. This method allows for:
  • Independent cinching, ensuring each loop maintains proper tension without interference.
  • Better load management, with loops sized and rated according to the expected forces from flight and landing.
  • Color coding or labeling for quick identification and correct joint matching.
  • Differentiated loop strengths, where inboard loops (handling greater loads) are made heavier than outboard join loops.
  • Length optimization, with forward stay loops long enough to pass through camber-adjusting components, while aft loops remain shorter as they do not require additional routing.
  • Dyneema construction, ensuring high strength and low weight.
To mitigate slippage and enhance stability, a small rubber snubbing ring can be placed over each loop, positioned outboard of the Joe Cup flange, to neatly secure the cinch.
Postby JoeF » Thu Mar 27, 2025 7:04 pm
Development note:
Hoops, Loops, Socks, Lines, Tubes, Fabrics, Films—Oh my :!:
Gather these and configure a UPHG :!:
Postby dhmartens » Thu Mar 27, 2025 8:41 pm
We are looking at the ultra portable predator.
Re: Ultra-Portable Hang Glider Design Movement:: UPHG
Postby Semper Fidelis » Fri Mar 28, 2025 12:51 am
JoeF wrote:Ultra-Portable Hang Glider Design Movement:: UPHG
I realy DO think that we need a new topic about UPHG, a new discussion start, just about it.
Please do so :thumbup:
Semper Fidelis
Semper Fidelis
Postby JoeF » Fri Mar 28, 2025 7:57 am
:idea: :idea: :idea: :idea: :idea: :idea: :idea: :idea: :idea: :idea: :idea: :idea: :idea: :idea: :idea: :idea: :idea: :idea: :idea: :idea:
All are invited to continue this topic thread
and kin matters in a new topic thread:
:arrow: :arrow: :arrow: :arrow: :arrow: Ultra-Portable Hang Glider(s) UPHG
Postby Chris McKeon » Mon Jun 09, 2025 3:56 pm
I wish to second Simper Fidelis thoughts, but with a added Descriptor. I love the idea of having a Short Pacible Predator.
Postby Bob Kuczewski » Tue Jul 22, 2025 4:53 pm
Chris McKeon wrote:I wish to second Simper Fidelis thoughts, but with a added Descriptor. I love the idea of having a Short Pacible Predator.
That's a tall order Chris!!
Users browsing this forum: Google [Bot] and 683 guests
