Postby JoeF » Wed Nov 12, 2025 2:21 pm
UPHG Design Note — Largest Tube in a Telescopic Nest
In a telescoping-tube system, give special attention to the largest (outermost) tube in the nest. Unlike the smaller tubes that must fit within another, the largest tube is free to feature localized exterior bulking—either:
1. Central-tube exterior bulking, or
2. End-region bulking.
Because this tube is never required to nest inside another, such bulking can be introduced without affecting packability. The overall tote length and diameter remain virtually unchanged, yet these bulking features can significantly improve frame integrity, buckling resistance, and joint strength.
Postby Bob Kuczewski » Wed Nov 12, 2025 5:05 pm
JoeF wrote:In a telescoping-tube system, give special attention to the largest (outermost) tube in the nest.
The outermost tube also protects the others during transport and storage!!
Postby JoeF » Thu Nov 13, 2025 10:59 am
Yes, indeed, Bob!
Exploration notes on a new direction of joins without Joe-Cups or Joe Straps, but rather hidden splining and shear pinning along with final anti-wobble little insert and a keeper for that little insert:
Sequence and mechanics
1. Storage
- The split-ring anti-wobble inserts are flexible enough to be stored separately without permanent deformation.
- Being small and flexible, they tolerate transport stress easily.
2. Child tube preparation
- Leave a thin Teflon or similar flat band on the child tube, positioned to later act as a backing or stop for the insert.
- This band stays on the tube throughout packing and tote — it does not interfere with nesting.
3. Assembly
- Press the split-ring insert into the radial gap between the child and mother tube.
- The band on the child tube acts as a firming surface, allowing the ring to be scooched over it, seating the insert snugly against the gap.
- This combination locks the anti-wobble ring in place, ensures radial support, and maintains alignment during spline engagement.
4. Spline and shear-pin engagement
- With the insert held snug by the band, you can slide the child forward until splines engage the mother’s internal spline set.
- Insert the shear pin last to lock axial position.
Advantages of this method
- Minimal additional hardware: no clamps or adhesives needed in the field.
- Flexible inserts are protected in storage but firm once in place.
- Assembly is repeatable, quick, and low-risk, even in field conditions.
- Ensures anti-wobble and torque transfer without interfering with shear-pin installation.
This approach gives you a clean, field-ready telescopic spar joint where all three functions — axial location, torsion transfer, and wobble suppression — are neatly separated and managed.
These notes above regards a big shift in a packing and spar-segment formation option that does not use Joe Cups or Joe Straps. The shift is to a situation where a set of two or more spar segments nest incompletely while allowing bulking of an end of spar segment and plugging an end of a spar segment. The nest grows in length by a couple inches or as desired for end-spar-segment treatment. There is a "stacking" in the nesting that occurs. This new option can occur when dropping the assumption of "full-length nesting" for packing and tote time. Bulking one end and plugging one end allows a firm shear pinning while protecting the vulnerable CF tube segment ends.
Special spline part bonding to the outside of the child tube and the i side of the mother tube about 1 inch from the end to about 3 inch from the ends allow a spline marriage for handling the spar torque until the spar torque meets its reaction with the keel or like means of reacting to the spar torque.
Sample new "stack nesting": Root mother tube No. 1 has plug in its keel-end that is say one inch long permanently bonded to the inside of that tube end; that plug prevents a child nested tube from going past that plug. But then the first child nested tube may nest toted with a bulky collar where the bulky collar does not fit inside the mother tube, but stacks by simply resting on the bulked end of the mother tube. Such formations could stop there if the spar is full then, but one might add another child tube with the same system of plug keelwise end and bulk collar wingtip end. Then there would be a three tube nest, but slightly stacked. Tolerate the stacking length for pack or design first mother tube, etc to be slightly shorter to help meet pack length wanted, be it 4 ft or 5 ft or 6 ft. Protecting the vulnerable CF tube ends and handling torque transfer are the causals for this adventure.
E.g., spline parts may start tube-inward away from the shear pinning.
Postby JoeF » Thu Nov 20, 2025 9:52 am
There may be some special keys in the designing of ultra-portable hang gliders; here are some that may be special keys for UPHG designing:
:arrow: Cross line anchoring into custom shaped collars
:arrow: Perma-end plugs to guard CF tube ends and provide a foundation for shear pinning and spar torsion handling
:arrow: Split-ring anti-wobble shimming
:arrow: Tube cleaning devices
:arrow: Low redundancy (at cost or performance)
:arrow: Stacked-telescopic nested CF tubing (as result of beefy collars and perma-plugs)
:arrow: Zippering
:arrow: Explore Dyneema and the like for some aspects of a design
:arrow: Explore conservative flight play
:arrow: Multi-packing
:arrow: Mixed technologies for hybrid solutions
Postby JoeF » Fri Nov 21, 2025 3:26 pm
A note:
Notice that the first largest tube in a stacked nest can be beefy collared at both ends no need for plug on either end. And that first tube can be beefy exteriorly in its center for handling buckling.
Postby JoeF » Sat Nov 22, 2025 7:14 pm
Note: inverted Y special plug above keel and three pins for posting; kite the afair from keel using broad anchoring.
Postby JoeF » Mon Nov 24, 2025 9:48 am
Or not.
Note:
Perhaps a removal doubly kited (to ends of keel) anti-wobble shimmed sleeve that has three projections integrated for capture of the three posts. The special sleeve would tote separate from frame stack-nested tubes.
Postby JoeF » Mon Nov 24, 2025 4:36 pm
That part placed at assembly on the keel may be tuned to exact spots.
This present note adds that just maybe the part also might anchor the pilot's tether.
The part spreads forces over a substantial part of the keel. Ever care to reduce cross-sectional ovalization (off-round deformation) of CF round tubes.
Postby JoeF » Sun Nov 30, 2025 4:49 pm
One of my UPHG wings will keep keel as the guard on torsion.
Postby JoeF » Mon Dec 01, 2025 4:43 pm
One of my UPHGs will be a hybrid. It will mix cross beaming with leading edge beaming. :D
Users browsing this forum: No registered users and 637 guests
