Postby JoeF » Wed Nov 25, 2026 12:53 am
Doug, I know of no attack of you by me, unless you are counting my polite request that you refrain from some fully off-topic posting in pointed-topic discussion threads, and post your says into appropriate topics.
Onward:: the following is AI-polished JoeF design exploration:
Note: Dimensions may change.
Note: Such coupling allows no loss of span via Child tube in Mother as rehearsed in many former notes. Indeed, at least a 1/4 in in span is gained per such coupling described below.
Note: Use of cost-effective CF circular tubing may still support torsion resist by special seating in the butting coupler. The plug might be with raised material fitting into filed recesses.
Note: The studied couple has not the wobble challenge of tube-insertion schemes; and thus no wobble-resist needs.
AI content from "Gemini":
Zero-Overlap Center-Flange Spar Coupler (WingOneMeter/Wing3/Wing3.5/Wing4/Wing5/Wing6 / WingBusable)
Engineered specifically for placement at cable-braced rigging nodes, this butt-joint coupler maximizes assembled wingspan from transit-friendly tube lengths while protecting raw carbon fiber (CF) tube ends. Because the rigging lines react transverse loads directly at the node, the joint operates in a zero-bending-moment zone—carrying only axial compression, localized shear, and torsion.
Architecture & Assembly:
• Stepped Internal Plug (2.25 in overall): A monolithic plug features a 0.25-inch proud center flange flanked by two 1.00-inch tenons stepped to match the inner diameters of the Mother and Child tubes. With bending moments eliminated at the node, the 1.00-inch tenons maintain coaxial alignment while transferring axial spar compression straight through the center flange. Both tubes seat flush against the flange, preserving 100% of packed tube lengths and adding a net 0.25 inches per node to the global spar span.
• External Sleeves & Active Clamping: Prior to joining, a 1.00-inch solid reinforcing sleeve is seated over the Mother tube end, and a matching external split sleeve is placed over the Child tube end. The global rigging line attaches via a lark’s head directly over the Child split sleeve; under flight tension, the lark's head cinches the split sleeve snugly onto the Child tube, using the internal plug as a solid anvil to react localized radial and shear loads without wall crushing.
• Vector-Preserving Flange Notches: Relief notches cut into the proud center flange allow rigging lines to pass cleanly through the node without deflecting their natural force vectors, keeping the load intersection centered on the coupler while eliminating line chafe.
• Castellated Torsion Lock: Matching castellations filed into the ends of the Mother and Child tubes and the seating faces of the center flange provide positive mechanical registration—locking the spar segments against wing twist while shielding the fragile CF tube ends from transit and assembly damage.
The AI added no concept that was beyond JoeF fed points.
Postby Chris McKeon » Wed Nov 25, 2026 1:11 am
I have not gotten any responded to My requests regarding information on this "KILLER, GREAT, IDEA regarding if I will be able to (SHORT PACK) My Predator. Well when John Heiney is up here performing an IRAN on My Predator. I will surely ask John about being able to Short Pack My Predator. Then if Zi were to do some poor decision making, when I am Flying Cross Country and have to land MILES FROM A ROAD. I EILL JUST Trans foorm My Predator into a Back Pack then casually joke My way along with My Predator on My Back to the nearest road. OK what I need to know is: scan this be done with My Predator?
Users browsing this forum: No registered users and 137 guests
