Yes, animals may lead the way. Water Safe-Splat. Ice and just enough friction, etc.
How might explosives play in
airbags or
short lift or
short airspeed regain or ?
JoeF wrote:Tow shares on project: ...
2. Plate inner backed with frequency-lowering shock-absorbing foam shaped to fit pilot curves. High-frequency tends to shatter bones; this is partially mitigated by lowering the frequencies of impact. Spreading the forces by outer plates also helps.
1. Motivation:
billcummings wrote:Resulting in a hammerhead stall too close to the ground.
The motor rpm didn’t increase at the start of the steep climb out.
It was overcast but that wouldn’t necessarily rule out flying into a thermal to cause the steep climb out.
Did the pilot push out to cause the steep climb out?
Did the pilot climb out of the lower wind speed gradient into a faster wind speed to start the steep climb out?
The cause of this crash should not be placed on a release failure or a weaklink failure.
A pilot should never tow in such a fashion that does not plan, at any second, for a weaklink failure, line break, scooter failure, encountering a thermal, or wind gradient.
Users browsing this forum: No registered users and 663 guests
