Here are instructions for a primitive taste of the realm:
1. Have a 3 m length of rubber band (loop many smaller bands together to make up a 3 m length.
2. Wear goggles.
3. Make two very-alike small model hang gliders (rough it by paperfold wings); tape a tail to each of the two wings, if needed).
4. Form an anchoring with a quick release at two places 15 m apart. Have a string connected to both releases; have the string be 30 m to allow slack aside while forming on the ground an equilateral triangle with the stretched rubber band as the base of such triangle; the aside vertex of said triangle will be the pilot-control place where operator will be pulling in order to simultaneously release the two wings from their temporary anchors.
5. Set the first wing in its anchoring- release.
6. Set the second wing in its anchoring-release.
7. Connect one end of the rubber band 3 m part to one wing.
8. Stretch the 3 m rubber ban and connect its free end to the the other wing.
9. Go to the control point arranged in step 4. above.
10. Jerk the side sline to release both wing simultaneously.
11. Observe the two wings move toward each othr and observe climbing from the kiting. If the wings and bridling are well done for stable kiting flight, then the cliimbing will occur for both wings.
Alternatives:
1.Fancy alternative: R-C radio-electric releases.
2. Slight compromise (giving up free-flight to explore simultaneous kiting of HGs): No pre-tension, no R-C, no rubber band, no firm anchoring, but have wings sit with correct attitude in a jig or even little dollies. Instead of rubber band, use string; have the strings from each wing go to a fairlead at the center of the 5 m separation; have the string long enough to go through the fairlead and to a large-drum that is arranged for manual reeling. Have the fairlead tethered with a long line away from the reel. Have the wings attached to the ends of line at the 15 m or more separated points.
Then begin reeling the line onto the drum; observe the wings being kited; observe the fairlead rising up away from the ground. Keep up the airspeed.
Use longer lines for the fairlead line, connecting line, and line for reeling the main connecting line. Observe; make notes; adjust wings for improved flights.
The alternative #2 is given now a graphic:
- PPKexperiment001.png (9.71 KiB) Viewed 4726 times
