Mostly.
(Yeah, I went three over - four, if you count the punctuation - but I'll try to make up for it on a future post.)
bobk wrote:Tad,
I was taught, and I support:
Hang Check + Hook-in Check
You're arguing for:
No Hang Check + Hook-in Check
In 3 characters or less, is this the crux of our disagreement here?
TadEareckson wrote:Mostly.
Let me pause to see if you agree with this characterization of the problem.
Christian Williams - 2006/09/19
Joe Greblo teaches a hook-in check the instant before launch. To him, a hang check is part of the preflight and has no value in confirming that you are hooked in at the moment of launch.
A HANG CHECK HAS *NO VALUE* IN CONFIRMING THAT YOU ARE HOOKED IN AT THE MOMENT OF LAUNCH.
TadEareckson wrote:Let me pause to see if you agree with this characterization of the problem.
Yeah, but before you spend a lot of time setting up a mathematical model make sure that it's addressing the right problems.
TadEareckson wrote:Christian Williams - 2006/09/19
Lemme edit that last sentence a bit...A HANG CHECK HAS *NO VALUE* IN CONFIRMING THAT YOU ARE HOOKED IN AT THE MOMENT OF LAUNCH.
And Joe WAS your instructor, right?
And remember that I've spent A LOT of time studying this issue.
Let's see, you're modifying a quote from Christian where he's paraphrasing Joe Greblo.
...and they're giving you a warning sign that you're on thin ice.
You're trying to say that Joe would find *NO VALUE* (mathematically ZERO) in a hang check with regard to hook-in statistics. But you know that's got to be false.
THE HANG CHECK IS MORE THE PROBLEM THAN THE SOLUTION.
IT SUBVERTS THE PILOT'S RESPONSIBILITY TO PERFORM A HOOK-IN CHECK.
Of course a hang check has *SOME* value in preventing hook-in failures.
Just before launch he reached back to make sure his carabiner was locked. A "crosswind" blew through, his right wing lifted, and before he was able to react he was gusted sixty feet to the left side of launch into a pile of "nasty-looking rocks." He suffered a compound fracture (bone sticking out through the skin) of his upper right leg. "Rookie mistake cost me my job and my summer. I have a lot of medical bills and will be on crutches for about five months."
In fact, I'd say that consistent hang checks would prevent a high percentage (maybe 90% or more) of the hook-in failures if people weren't implementing any other system.
Rob Kells - 2005/10
Several pilots have launched unhooked after doing a hang check because they were distracted and unhooked from the glider, and then, remembering having done a hang check earlier, they ran off the hill unhooked.
To find out, I've just left a message for Joe on the question, and I'll let you know when he gets back to me.
Incredible volume of stuff on this, so i will be brief.
With each flight, demonstrates method of establishing that pilot is hooked in just prior to launch.
The Lift and Tug Method, as with all methods, is merely a tool which we use to accomplish a goal or goals.
It is not perfect and has been known to fail miserably.
The best piece of advice I read was to always be thinking and do not get stuck in the rut of always doing it the same.
George Whitehill - 1981/05
Just doing a hang check is not enough. Don't get me wrong, a hang check is a very important step that should be done prior to every launch. A hang check shows the pilot that he/she is the correct height above the bar. It also assures the pilot that harness lines and straps are untangled.
The point I'm trying to make is that every pilot should make a SECOND check to be very certain of this integral part of every flight. In many flying situations a hang check is performed and then is followed by a time interval prior to actual launch. In this time interval the pilot may unconsciously unhook to adjust or check something and then forget to hook in again. This has happened many times!
If, just before committing to a launch, a second check is done EVERY TIME and this is made a HABIT, this tragic mistake could be eliminated. Habit is the key word here. This practice MUST be subconscious on the part of the pilot. As we know, there are many things on the pilot's mind before launch. Especially in a competition or if conditions are radical the flyer may be thinking about so many other things that something as simple as remembering to hook in is forgotten. Relying on memory won't work as well as a deeply ingrained subconscious habit.
In the new USHGA rating system, for each flight of each task "the pilot must demonstrate a method of establishing that he/she is hooked in, just prior to launch." The purpose here is obvious.
Stewart LaBrasca - 2009/08/27
Chehalis, Washington
How many of you have ever helped airlift a fellow pilot off the hill after launching unhooked? Because this is a (tongue in cheek) self regulated sport, there is no SOP for hooking in prior to launch. Therefore it is obviously up to the PIC to make sure he is hooked in. As a commercial pilot for an airline I am glad that there are mandatory flows and checklists required.
The second pilot was distracted by backing off launch to get his helmet, which he had forgotten. While doing so he thought of a pilot who launched unhooked at Lookout Mountain as a result of the distraction of retrieving his helmet.
While doing so he THOUGHT...
Allen Sparks - 2010/09/06
Evergreen Colorado
Oscar,
I'm very happy you weren't injured.
Helen,
Thanks for the Tad 'lift and tug' reminder.
I have launched unhooked and experienced the horror of hanging by my fingers over jagged rocks ... and the surreal result - i.e. not being significantly injured.
I am a firm believer in 'lift and tug' and the mindset of assuming I am not hooked in. It is motivated by the recurring memory of my own experience ... and the tragic deaths and life-altering injuries of good friends.
As with all tools, it is the person swinging the ax and how it is swung that determines success.
That's a very good post.
Tad, I'll be happy to carry on with this discussion, but I'd much rather allow Pilgrim's comments be the last word.
He sums it up very well, and I think that would put a nice cap on the discussion.
Can we agree to let this be for a while?
I am happy with the notion that all US Hawks ratings will require that the pilot demonstrate a method of ensuring a safe connection to the glider immediately prior to every launch. Maybe we can vote on that and be done with it.
Thanks again Pilgrim. "Blessed are the peacemakers ..."
Bob Kuczewski - 2010/05/30
To be honest, that's hard for me to say for sure in this case. But the topic did come up when I was on the Board, and the first reaction by some "leaders" in USHPA was to call the USHPA lawyer to muzzle him with a nasty letter. As a Board member I argued against that approach because I felt that it would be better to open lines of communication rather than shut them with legal threats. Fortunately, cooler heads prevailed and some of the Directors who knew him were called in to help. As far as I know, things were resolved peacefully without further escalation.
If the tedium of the goddam rut gets to BE too much to handle...
TadEareckson wrote:Bob,bobk wrote:Let's see, you're modifying a quote from Christian where he's paraphrasing Joe Greblo.
1. And changed/distorted the meaning of the original sentence how?
TadEareckson wrote:bobk wrote:You're trying to say that Joe would find *NO VALUE* (mathematically ZERO) in a hang check with regard to hook-in statistics. But you know that's got to be false.
Totally dude.
TadEareckson wrote:Pilgrim,Incredible volume of stuff on this, so i will be brief.
Doesn't hafta be. We could just go with:With each flight, demonstrates method of establishing that pilot is hooked in just prior to launch.
But it doesn't look like that's ever gonna happen.
Users browsing this forum: No registered users and 569 guests
