Note regarding segmented stuffer just mentioned. The string spokes may be judiciously lengthed and placed to stay a non-circular cross-section to help form desired airfoil potion.
Note: Consider applique at LE before wrapping DS sail: compressible foam. In tote segments of foam applique can squeeze down to low volume. Or the segments of compressible foam applique could be worn by the pilot during trek to th e flight sight. The foam coordinates with the spar, spoke-shaping stuffer, and sail to obtain desired airfoil shaping.
Note: Have beam spreaders every 30 inches. Have spar couplers at the 5-ft spar-segment ends. Have the wing spreaders overlap the spar beam (angles) and firmly bolt-joined or hard lashed or the like to give anti-twist to the spar segments. Have the 5-ft spreaders be joined by the spars at the 1-ft-from-TE and LE point; this will efficiently use the angle-leg height and reduce the unpinned beam length of the spreaders to 4-ft, with 1 ft aft of aft spar. SS or DS HG hereabouts.
Spreaders may be good candidates for "double tapering" design to obtain least mass for the HG; opportunity for one-part spreader or two-part spreaders; two-part spreader might give opportunity for wing chord to exceed 5-ft, if wanted. Thus 6+6=12 spreaders in addition to the keel that also spreads the two parallel spars. Spars: angles (with some casing set at assembly at site.). Eight (8) couplers for sparing: 4+4.
- papernotesMarch16of2023small.jpg (67.58 KiB) Viewed 6526 times
Note: Toted angle beams at assembly might receive some casing, full or partial. Casing could be sacrificial tape or hook-and-loop wrap or sock case, or the like; this can be explored to counter beam's angle's leg spreading during compression of spars from flight loads in a KP-QP rigging affair. Tolerate the draggy rigging.
Consider a TE bar set on the TE tips of the spreaders. Rectangular. Receives wrapping sail and firms the TE shape. Bar can be in tote segments of 5-ft or less. Bars will pack well.
Add central SS sail areas filling the keel aft end to 10-ft out on side wing, say 5-ft by 10 ft legged triangle, not right as sweep puts the triangle not right. But approximately 40 square feet is added to the HG. Rough area of HG: 190 sq. ft. 5,5,5,5,5,5 by chord 5; plus aft special area. Rough: 5x30+40=190 rough.
