Rick Masters wrote:Ever notice how much better a thermal pilot you become low over hostile terrain?
One afternoon I left Mazourka with 12,000 MSL and reached the Inyos only to discover the easterlies flowing downslope. I flew out into the valley but found no lift. Two miles from my motorcycle, I was down to 300 feet. Not wishing to walk, I concentrated on the Snooper's occasional beeping to circle in warmer areas of ground heat. Although my variometer was indicating nothing but zero sink, after a series of 360s I would find myself 30 feet or so higher. Gaining what little I could, I would head north and repeat the turns the next time the Snooper "beeped." I lost 200 feet during the first mile and completed the second with only 100. After landing, I got a funny feeling that I could have kept going indefinitely at 100 feet! I have always admired the exceptional hang glider pilots who could do this kind of thing but I had never been particularly good at it. Now the Snooper was making it almost easy.
-- "Explorations with the Thermal Snooper" by Rick Masters, Soaring Magazine - The Journal of the Soaring Society of America, August 1987, pp. 24-29
https://web.archive.org/web/20110902024918/http://www.cometclones.com/illusion.htm
Bill Cummings wrote: to stay in the harness long enough to do a range of motion rigging adjustment test with the front restraint R&D.
I still hope to do this test and use the GoPro so others can offer up suggestions.
reluctantsparrow wrote:Bill Cummings wrote: to stay in the harness long enough to do a range of motion rigging adjustment test with the front restraint R&D.
Had some time today to rig up the ARPR today to check for range of motion.
Range of motion is okay if you are going to flare from only the basetube.
The Rocking up action required to perform safe flares from the downtubes required far too much slack added to the restraint line to provide any protection at all.
I ran the restraint from one corner of the upright/basetube junction, over the midsection of the pilot (since that is the only place on the harness I am using that offers loops), and over to the other upright/basetube corner. I then lengthened the restraint line until I could perform full push out in the rocked up position.
so much slack was needed that i could stand up,walk forward, and bump my head into the keel of the glider at the flying speed angle of attack.
I know this is not the perfect configuration ARP outlined but it was close and modified only to do a quick check of range of motion. the problem is created by the slack needed to rock up and push out.....where a rear restraint line does not pose this problem.
Not saying it wont work....just saying the way I rigged it up wont work.
reluctantsparrow wrote:Just did a test of my bermuda triangle line system with a short section of bungee in the system. I am amazed how much forward and upward travel the triangle system allowed even though it was attached at the exact same point on the wires as bar was during the bungee/leash/attached to the keel/ set up where the leash runs under the bar.
Might have been the wire attachment on flexing wires that allowed so much travel? hmmm, have to slow mo it some more...but..
So far, I think the bar idea I tested last time looks the most promising but it might have been a fluke.....
going to Rig up the Bar again, as that has produced the best result and re-test until I know its not a fluke.
Users browsing this forum: No registered users and 650 guests
