Re: Global Meteorology for Hang Glider Pilots
Postby Rick Masters » Wed Feb 10, 2016 11:21 pm
Postby JoeF » Thu Feb 18, 2016 8:04 pm
Postby Rick Masters » Fri Feb 19, 2016 8:57 pm
Postby Rick Masters » Sun Dec 11, 2016 8:03 pm
Three of the best weather blog sites out there:
December 10, 2016
Subtropical moisture plume bringing heavy Sierra Nevada precip; widespread active weather this week
http://weatherwest.com/
It’s interesting to note that the Arctic basin itself remains extremely warm relative to average for this time of year–and that the Alaskan blocking pattern is occurring very close to the region of ongoing record low sea ice extent in the Bering Sea. At least in a proximal sense, it does appear that the upcoming unusual weather pattern in California this week is related to the extremely anomalous circulation pattern in the Arctic.
November 20, 2016        ARCTIC NEWS
http://arctic-news.blogspot.com
December 7, 2016        WEATHER UNDERGROUND WUNDERBLOGS by Jeff Masters and Bob Henson
Autumn 2016: Warmest in U.S. Weather History
The nation’s average September-to-November temperature of 57.63°F was a full 1.05°F above the previous autumn record, set way back in 1963, and it was 4.08°F above the 20th-century average (see Figure 1). The record-setting margin of more than 1°F is a hefty one for a temperature record that spans an entire season and a landmass as large as the 48 contiguous states.
https://www.wunderground.com/blog/JeffMasters/archive.html?year=2016&month=12
Postby Rick Masters » Wed Dec 21, 2016 12:08 pm
December 20, 2016
North Pole forecast to warm 50 degrees above normal Thursday
https://www.washingtonpost.com/news/capital-weather-gang/wp/2016/12/20/forecast-north-pole-to-warm-50-degrees-above-normal-thursday-near-melting-point/?utm_term=.f7216087e51e
Computer models project that on Thursday, three days before Christmas, the temperature near the North Pole will be an astronomical 40-50 degrees warmer-than-normal and approaching 32 degrees, the melting point. ...Arctic sea ice levels are at a record lows. In November, the Arctic usually gains ice, but over a period of five days it saw 19,000 square miles of ice cover vanish, which NOAA called “almost unprecedented”.
Postby Rick Masters » Wed Jan 18, 2017 6:09 pm
New series of storms to bring renewed California flood concerns, especially in south
http://weatherwest.com/archives/5526
Postby Rick Masters » Thu Feb 16, 2017 5:12 am
The atmospheric river storm that topped the Oroville Dam
Now, the next ten days:
Computer forecast models indicate a powerful jet stream will continuously pound California over the next ten days and bring copious amounts of moisture from off of the Pacific Ocean into the state. This 10-day loop of predicted upper-level winds at 250 mb are in 6-hour increments from today until Thursday, February 23rd; maps courtesy tropicaltidbits.com, NOAA/EMC (GFS)
Discussion by meteorologist Paul Dorian:
https://www.vencoreweather.com/blog/2017/2/13/1025-am-california-has-a-brief-break-before-getting-pounded-again
Dramatic erosion of greenschist bedrock at the emergency spillway
Sacramento Express?
Previous discussion on this forum of the ongoing potential disaster at Lake Oroville Dam
http://ushawks.org/forum/viewtopic.php?f=15&t=2673&sid=635e359d37bfb7c2444b82ae73764519
Realtime reservoir level, inflow and outflow
http://cdec.water.ca.gov/cgi-progs/queryF?s=ORO
Ventusky precipitation accumulation tool
WARNING: Not for the faint of heart
https://www.ventusky.com/?p=34.38;-118.21;7&l=rain-ac&t=20170225/12
Atmospheric River realtime
Postby mike » Thu Feb 16, 2017 10:54 am
Thanks for the Cal weather 411. Very interesting.
mike
Postby eagle » Thu Feb 16, 2017 11:58 am
Hole of Knowlage.jpg (24.51 KiB) Viewed 6303 times
~ Believe some of what ya hear, and Most of what ya See & Feel ~
Please Expain.jpg (9.59 KiB) Viewed 6303 times
Postby Rick Masters » Thu Feb 16, 2017 1:18 pm
Wednesday, February 15, 2017
Getting ready to pour concrete on rocks stacked at the edge emergency spillway
Where's the rebar?
YOU KNOW WHAT THEY'RE DOING IN THEIR PANIC?
JUST PUMPING CONCRETE OVER THE BOULDERS.
IT WON'T WORK!
CONCRETE CURING
Curing concrete will make your concrete stronger and better, but only if you do it right-timing is key
By Bill Palmer, Concrete Network Columnist
When concrete is born-when you place fresh concrete where you want it to live out its life-it's like a baby: very sensitive and easily ruined. If you take good care of it, when it's young it will grow up to be a strong and reliable adult; neglect it, and you'll be sorry! Curing is all of the things that we do to keep our concrete baby happy during the first week or so of its life: maintain the proper temperature (neither too hot nor too cold) and dampness (I know, most babies prefer to be dry-concrete likes being difficult). Curing is easy to skip in the instant but that will have a major impact on the quality of your finished work. While curing is important for all concrete, the problems that arise from not curing are most obvious with horizontal surfaces. An uncured slab, whether decorative or plain gray, is likely to develop a pattern of fine cracks (called crazing) and once it's in use the surface will have low strength that can result in a dusting surface that has little resistance to abrasion.
ALLOW PROPER TIME TO WATER CURE
After concrete is placed, the concrete increases in strength very quickly for a period of 3-7 days. Concrete which is moist cured for 7 days is about 50% stronger than uncured concrete.
Now we know why they finished the dam a year ahead of time.
It's time to start packing up your stuff if you live in Sacramento.
Oroville Emergency Spillway: Does this Look Like Bedrock to You?
February 13th, 2017 by Roy W. Spencer, Ph. D.
http://www.drroyspencer.com/2017/02/oroville-emergency-spillway-does-this-look-like-bedrock-to-you/
I’ve had a little criticism here and on Facebook that I’m not a geologist, so I shouldn’t be second-guessing the Oroville Dam engineers. They called for evacuations last evening out of an abundance of caution. That the emergency spillway is no doubt built on bedrock, and so it is safe.
Well, if it was only out of an abundance of caution that evacuations were ordered, why did emergency officials claim that there might be only one hour until the concrete weir topping the emergency spillway would fail? Hmmm?
And take a look at one of the ravines that eroded from only a little over 24 hours of flow over the emergency spillway
One of two major eroded areas just below the emergency spillway of Oroville Dam (Feb. 13, 2017). The little yellow spots are people.
Does that erosion feature look like it’s cutting into bedrock? Even though the spillway is supposed to handle 250-350,000 CFS, it was only ~10,000 CFS total flow across the 1,700 ft. long weir that caused this.
An Army Corp of Engineers engineer named Joe Countryman said in a Sacramento Bee interview that, essentially, if the emergency spillway was overtopped again, it would fail and that the hydraulic hammering action of the water could possibly eat away the fractured greenschist and "drain the reservoir." :o
http://www.sacbee.com/news/state/california/water-and-drought/article132356269.html
The latest press conference held shortly after noon today suggested that officials are avoiding hard questions. At one point a reporter asked, “With two parts of the system compromised (the main spillway and emergency spillway), how secure can people be?“. The speaker was not allowed to answer the question.
I honestly don’t know what’s going on, but if I lived in the flood plain (and now one of the near-200,000 people evacuated), I’d be wanting some more definitive information.
Users browsing this forum: No registered users and 311 guests
